Results 1 to 7 of 7
    Mar 29 2016
    calgary alberta canada
    Timing belt and water pump help please
    Hey guys so my daily driver is a 2003 Audi A4 quattro B6. I did some reaearch and called my local Audi delaership. They said that the timing belt and water pump was done at 116,000KM. I just bought the car and its at 177,000KM. Hiw much more life do you think i can squeeze out of it safely before my next tb and wp
    Live in Canada so car is in kilomoteres
    Senior Member Two Rings Rus_ninja's Avatar
    Nov 30 2013
    I would change it asap. You are playing with fire in the 65-75 range.
    Nov 30 2013
    Oh crap did not see km, I think you are good then. I would change it any way, just to be safe.
    Mar 29 2016
    75k miles is almost 110,000 km
    So if it was done at 116k km amd the car is now at 176k i should still be good?
    Oct 28 2014
    ON
    Yes, 120K per 1.8T timing belts is a safe conservative number. The fact that it was done at audi and it's on record is reassuring.
    Forum lore goes 120 K +/-100K :p
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by AudiB6Q View Post
    Did they replace the tensioner when first TB & WP was replaced? If not, Check your tension on the belt, and check belt for physical condition. If both are good, I wouldn't worry. You will be safe until 200-220,000km.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Mar 29 2016
    Thanks for your input fellas i appreicate it
