Results 1 to 9 of 9
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Installing B7 S4 Rear Recaros in B5 S4
    I have seen a couple people install B6/B7 rear Recaros in our sedan B5's.
    Does anyone have any install pictures or tips?
    This is one car that I have pictures of. (not the best)
    I have currently have a set of rear recaros. The mounting points are the same, but they will not sit all the way back.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Look up "B Thumper". He has done what you want.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    May 16 2008
    WA
    does this car actually run yet?
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    It can be done easily as the b5 rs4 uses
    the same model of recaro's as the b6/b7 s4's stateside.
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Quote Originally Posted by landfill View Post
    I don't believe so.
    I talked with someone in the UK and he has both rear B5 RS and B7 S4 and he said they fit much differently.
    - - - Updated - - -
    Quote Originally Posted by s vier View Post
    Thank you. I'll take a look.
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Bump
    Nov 14 2013
    The brackets are different but the model of seat is exactly the same. Recaro topline's with Audi branding that's all.
    - - - Updated - - -
    You just have to come up with
    a set of brackets.
    Veteran Member Three Rings -Billy's Avatar
    Feb 13 2013
    Altoona, PA
    I have no knowledge of this...but if you can come up with a template for a bracket and send it to me I have a plasma cutter and a break. I imagine I could make something up real easy for a literally a couple dollars in materials. Let me know if that's something you want to do.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    B thumper has b5rs4 avant seat backs.
    Same process pull off the leather skin and foam and put it on a b5 frame
    It's time consuming but not hard
