    Established Member Two Rings Brendon11's Avatar
    Nov 17 2013
    2010 A4B8; 2014 Q5TDI
    BPort, CT
    A few items that need attention- 2010 A4
    Hey guys,
    I think I have a compound issue here, but I want to put it out there for you to comment on.
    A little background. We have a 2010 A4. My wife went off the road back in January and smacked into a tree. Messed up the front passenger side- swing arm, fender, hood, and so on. Had a broken engine mount and then the starter failed. All sorts of fun.
    Regardless, I took it to the body shop for repairs. They did a great job on the outside, but they had all sorts of problems with the inside! Everything from seat belts locked up to all sorts of error codes.
    Well, here's where I'm at. Car is running fine [mostly]. Only issues that I see are "Parking Light Failure", the "Airbag" light is on, the rear seat belts are frozen, and on occasion, the car takes a little bit to 'catch'. It's kinda slow to turn/start.
    As I said, I think there are multiple problems going on here...
    Regardless, here is the VAG com scan log. Maybe you guys see something?? Any pattern? Where should I start? Do I have to replace all the rear seats in order for the airbag light to turn off? I've read that the parking brake error might be tied to the airbag as well....
    Any help is greatly appreciated!! THANK YOU!
    VCDS Version Release 15.7.4 (x64) Running on Windows 7 x64(Parallels)
    Data version: 20160216
    www.Ross-Tech.com
    Saturday,19,March,2016,14:28:14:28374
    Chassis Type: FL (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
    VIN: WAUBFAFL2AN063777 Mileage: 115160km-71557miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    No fault code found.
    Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
    Component: ESP8 quattro H04 0030
    Revision: -------- Serial number: --------------
    Coding: 150D10
    Shop #: WSC 02391 823 56573
    VCID: 7AFBF189F5B18FEE30-802F
    1 Fault Found:
    013 - Check DTC Memory
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
    Component: KLIMA 1 ZONE H08 0171
    Revision: A1000000 Serial number: 01100420101559
    Coding: 64002000
    VCID: 7DF1FA95E49FB8D615-8029
    1 Fault Found:
    01271 - Positioning Motor for Temperature Flap (V68)
    001 - Upper Limit Exceeded
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H41 0610
    Serial number: 003GLD0D77E8
    Coding: 303837354230303030304A55304C384B3053
    Shop #: WSC 02145 785 00200
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 45815275C4CF30160D-8011
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
    Component: BF-Gewichtss. H01 0030
    Serial number: 5810000R1000006VYQ
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME50324155+
    Crash sensor for side airbag; front passenger side:
    Serial number: 6344MSME5220254F9
    Crash sensor for side airbag; rear; driver side:
    Serial number: 6352QSME2452301A4
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 6362QSME7A5A3308O
    6 Faults Found:
    9438491 - Igniter for Driver head airbag
    B1005 1B [137] - Resistance Too High
    MIL ON - Confirmed - Tested Since Memory Clear
    9439515 - Seat Belt Tensioner Igniter; rear; driver's side
    B1009 1B [137] - Resistance Too High
    9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
    B1008 1B [137] - Resistance Too High
    9441819 - Safety belt tensioner igniter; rear; center
    B1012 1B [137] - Resistance Too High
    9443859 - Driver's Front Airbag Crash Sensor
    B101A 13 [137] - Open Circuit
    9444115 - Front Passenger's Front Airbag Crash Sensor
    B101B 13 [137] - Open Circuit
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
    Component: KOMBIINSTR. H20 0255
    Revision: 00300000 Serial number: CIM33R54A
    Coding: 831309000300D705020000
    VCID: 316916A568478CB6C1-8065
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 114870 km
    Time Indication: 0
    Date: 2016.02.16
    Time: 15:16:07
    1 Fault Found:
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000609405
    Shop #: WSC 00000 000 00000
    VCID: 34671FB19755B99EAA-8061
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
    013 - Check DTC Memory - MIL ON
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    End-------------------------(Elapsed Time: 02:50)--------------------------
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    get a golf
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Do you have a VAGCOM? The air bag light can be turned off within its own module (separate from generally clearing codes). If not, I have one and I live nearby and am happy to help troubleshoot.
    If the seat belt tensioners keep locking up, they might need to be replaced... I'm not sure if those are only supposed to be used in one accident or what. Dealer would know.
    You may have a parking light bulb out, as well, and it could be unrelated to the accident.
    The starter could just have been installed incorrectly, or not be an OE part. If the part isn't expensive and it's a DIY, it might be worth replacing yourself or, if it bothers you a lot, having Fairfield Audi adjust or replace it. They're stand-up guys and won't charge you for work you don't need.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Nov 17 2013
    BPort, CT
    Quote Originally Posted by Luis_Heineken View Post
    get a golf
    super helpful, thanks!
    Quote Originally Posted by Project Quattro View Post
    Thanks for the reply!
    Yes, I have a VAGCOM but I just don't want to clear codes because I can, without addressing the problems first. I'd imagine that once cleared, the airbag light will come back on if the faults are related to the seat belts!
    I've been reading that the seat belts have an ignitor that may have gone off. I guess I have to pull the back seats to see if they are locked.
    With that said, I wanted to see what you guys thought about the codes. "Intermittent supply voltage"? Check "DTC memory"? and of course the "resistance too high" fault...?
    Mar 24 2014
    Quote Originally Posted by Brendon11 View Post
    After re-reading this... Call your insurance company first, but I would suggest taking it to the dealer. Whomever did the repairs probably missed replacing some minor things, but almost every single thing in these cars ties into the computer system and will throw errors. I would have them use their scan tools and give you a quote to make it right, and see if your insurance will cover the cost. They should, since it is accident-related, although you may have to push them on it. I suspect that you need new seat belts (or some related sensors), a new ABS sensor or reprogram of the one you have, and possibly a passenger air bag sensor, or reset of same. The ABS and parking brake failures are likely tied to the same issue. The HVAC may be unrelated, but it may also be related. The dealer can likely confirm.
    I highly recommend Fairfield Audi's service department, they'll take care of you and they can also get you a service loaner.
