Results 1 to 13 of 13
    Aug 25 2015
    ohio
    Xpel install tomorrow
    So I am moving down to Tampa and will be leaving on Monday to start the journey. I figured before I drive down there I wanted to get some protection from rock chips and the like. I found a local xpel factory trained installer and will be getting just the front bumper done tomorrow. Is there any questions that I should be asking after install or any advice from the people that have had it done. I have read a couple different threads on the subject but wanted to get some more recent opinions. Thanks in advance!
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I would recommend also getting the hood and front fenders as well.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jul 10 2015
    Make sure the edges are wrapped for a clean look, otherwise there'll be a visible line on the edge of wherever you had it applied.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Quote Originally Posted by dragoon218 View Post
    If you are going to Albert at Block A Chip then you are in good hands. He did mine. Just tell him to wrap all edges.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Aug 25 2015
    ohio
    Yes I will be going to block a chip, not to sound stupid but what do you mean by edges? Would the normally not tuck the film around?
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Quote Originally Posted by jmeenach View Post
    +1
    [B]Current: Shopping now....
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Usually the film is cut flush with the edges so you can see where it ends and it won't protect the edge. You can ask for the film to wrap around the edges for a cleaner look and added protection. My installer charged a small additional fee to wrap edges which I think was well worth it as edges are protected and seams are minimal.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Aug 30 2009
    Fredericksburg, VA
    Quote Originally Posted by Powderhound View Post
    wrapped edges are a must...much cleaner look IMO
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    I'm not a fan of the bikini wrap (half hood/fenders/etc). Spend a little extra, it's worth it.
    Also (and most people don't know this), Xpel is a porous film (it breathes) and also self-heals. There is no such thing as a perfect application. There will ALWAYS be some small bubbles/etc. when the film is applied. Allow the film 2-3 weeks out in the sun to cure and "gas-out" the bubbles, and it will look perfect. Small visible bubbles will automatically work themselves out.
    DO NOT confuse small bubbles with stretch-marks or wrinkles as neither will progressively work themselves out.
    TAKE PICTURES and congrats on the purchase!
    Dan Lensch
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Aug 25 2015
    ohio
    Quote Originally Posted by Lensch09 View Post
    Dan Lensch
    I am not a fan of that as well, I will be doing the entire hood and fenders when I get down to florida. I have to drop almost 3k for the move on sat so I will be tapped from buying car parts for the rest of the month. I at least wanted the bumper done before I drive down. thanks for the advice also! Really don't want to screw it up and have to pay to get it redone. I am sitting in the waiting room now.... fun times
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    if you plan to get it redone after you move i would just do the entire hood and your quarter panels.
    do the front bumper after you get to florida, since its plastic if you do get any chips these can be easily fixed with touch up paint and covered in xpel after, your hood and quarters are metal and should be protected first and foremeost...
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Nov 28 2015
    Montreal, QC
    slightly OT, if you have rock chip on your headlight already, can a layer of xpel fill those imperfection and make it smooth again ?
    Mar 21 2015
    Sounds like your crunched for time but you should have a full paint correction before wrapping.
