Results 1 to 9 of 9
    Established Member Two Rings renold458's Avatar
    Nov 25 2015
    2002 Audi A4 1.8T Quattro
    East Providence, RI
    Question: How Do I Attach OEM Wheel Center Cap?
    So one of my center caps have fallen off a while ago because the knucklehead of an owner before me broke one of the clips on the cap and tried "gluing" the cap to the wheel with some goop and his little DIY didn't last. I bought a new set of caps and removed the jizz off the wheel that was left and can't for the life of me attach the damn thing. Any suggestions?
    They're the stock alloys btw.
    Veteran Member Three Rings Lauri0112's Avatar
    Jan 29 2015
    Estonia
    Bought the wrong one maybe? Would imagine that they should just pop on, so to say.
    Nov 25 2015
    East Providence, RI
    They're the right ones, model number matches up and they're identical to the ones on the car. I managed to remove one a while back and also had a tough time putting it on and have no understanding of how I did it.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    They literally pop in. Do you have the metal c-clip that goes behind the cap in place?
    2019 SQ5 Prestige
    Nov 25 2015
    East Providence, RI
    If that's the metal ring that I see on the back of the cap, yes sir
    Apr 07 2011
    It takes some force to get them in there, don't be shy. They do just pop in.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    You're probably not lining up the notches on the wheel to the divets on the back of the centercap.
    Established Member Two Rings Jborch8's Avatar
    Apr 30 2012
    Oil stains
    Issaquah, WA
    Quote Originally Posted by claudiovagkraft View Post
    This. Make sure those D looking notches line up. That was the issue I first had when trying to very forcefully try to get those caps in.
    2005 A4 B6 1.8t Avant - Moro Blue
    Stage 1 APR Tuning / Eibach Pro Springs with Bilstein shocks
    Nov 25 2015
    East Providence, RI
    Quote Originally Posted by Jborch8 View Post
    Thanks guys! That was my issue. I literally almost lost my back just trying to get those in but I finally got em in when I lined those notches up. At first I was lining it up with the valve stem which worked for 3 of the wheels but the last one so I appreciate that.
