Results 1 to 36 of 36
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    Trans mount insert selection
    Hi All,
    So on my future to-do list is the common mod of installing a transmission mount insert on my 12' DSG S4. Seeing as ECS was just added to the list of suppliers, 034, Eurocode, or ECS, I'm trying to gauge which to go with. As all are around the same ball park price, I can't see much advantage of one company over the other, with the exception that ECS provides you 2 new oem "torque to yield" bolts to replace the ones removed. I'd like to get a poll going on who re-used these bolts, and if so, have you had any issues? Thanks!
    Nov 08 2015
    Newtown sq, Pennsylvania
    I just put in Ecs diff mounts and eurocode tranny mount, reused tranny mount bolts without an issue. Just a slight NVM but not enough to bother me.
    2016 Glacier White S4 P+
    6MT | Black/Magna Nappa Leather | Tech Package | Carbon Inlays | Sport Diff | Alu-Optics | Black Optics | B&O | LED Interior Lights |
    25% Tint | LED Fogs | 19" BBS CS5 Winter Setup | Eurocode sways F+B | Eurocode endlinks F+B | Deval Diffuser+Front Lip | | ECS 10mm Spacers | USP Stainless clutch line | E-codes | ECS Diff mounts | Eurcode Tranny mount |
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    I have all Eurocode mounts, I just like the anodized red mounts, very happy with them! And yes reused all the bolts.
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Sep 11 2015
    Western Mass
    Did you re-use the "Torque to yield" bolts on the trans mount?
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
    Mar 21 2015
    I have all of the 034 mounts and reused all of the original bolts.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    034 one here, no issues, reused the bolts. Support the originator.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 02 2014
    just purchased the eurocode mount for 40 bucks on sale. i think the 034 mount is around 75? not sure which ballpark you go to but that's a decent gap if you ask me.
    Oct 02 2006
    Wadsworth,OH
    Torque to yield bolts are used for a reason. We've all reused them a time or two but really should be replaced every time. It's a small price to pay for peace of mind.
    Jason
    Oct 03 2011
    2007 S46MT, 2011 S46MT,2009 R1
    Sacramento
    the REAL question is, who has all the benefit of a tighter drivetrain with NO vibrations/noise in the cabin??? and which did you use
    Nov 08 2015
    Quote Originally Posted by Rbb1485 View Post
    Yes. I reused sway bar and endlinks bolts as well. Did them all together, car only has 5k miles if that makes a difference.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by infinkc View Post
    +1. I went with the 034 mounts and reused all the original bolts, but I added loctite.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Sep 11 2015
    Western Mass
    Quote Originally Posted by Petrolhead View Post
    Point of this thread is not to compare ball park sizes but rather if you re-used original torque to yield bolts and if you experienced any issues as a result. And yes SacAudi, also to your point, which supplier provides tighter drivetrain with the least amount of vibrations/noise in cabin
    Mar 05 2014
    SF Bay Area
    I replaced the torque to yield bolts with grade 8 bolts. when I looked at the stock bolts I could clearly see where the threads had stretched.
    Apr 02 2014
    you asked the forum to help you make a decision on which mount to go with. i was just giving you another factor to help make your decision and letting you know they are NOT in the same ballpark as you thought. eurocode sells bolt kits for most other products in it's line up so i take that as a sign they are not required for this particular mount but hey, if bolts are that important to you then go for it. your welcome.
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Quote Originally Posted by BlownOne View Post
    +2 no issues here
    Sent from my Note 5
    Bryan
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    The trans mount torque yield bolts only have 15 ft-lbs on them. I gambled and reused the originals. I'm guessing people who have issues reusing those bolts over torqued them by quite a bit.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    I have
    034 engine mounts,034 transmission mount & 034 diff mounts.
    I've never noticed any extra cabin noise
    6MT not DSG
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Oct 03 2011
    Sacramento
    Quote Originally Posted by xpoweruk View Post
    I have
    6MT not DSG
    Thank you! And I imagine the feel from tightening up the drive train has you grinning ear to ear every time you drive? or how would you describe it?
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Jason
    +1
    Drive a $60k German sports sedan......balk at swapping out some cheap bolts. Just seems foolish to me.
    Quote Originally Posted by Scumbucket View Post
    Grade 8 has nothing to do with a torque-to-yield bolt. Grade 8 is merely a shear force rating.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Oct 14 2012
    Empty...for now...
    SE PA
    Sort of off topic, but I have a 2015 6MT with 034 transmission mount insert and Apikol rear differential bushing (the 'race' one, can't remember the color). When I am in 1st gear at light throttle and at a crawl (i.e. in traffic), the car is bucking forward and aft. I thought the combination of these two modifications was supposed to diminish or eliminate this phenomenon but it feels just as bad, if not worse, than stock. Anyone else with the 034 transmission insert experiencing this?
    SOLD 2015 Daytona Gray S4
    Mar 21 2015
    ^ I have all of the 034 mounts and don't experience that.
    Oct 14 2012
    Empty...for now...
    SE PA
    Thanks for the input. Maybe I need to check the bolts holding both pieces to make sure they aren't coming loose.
    Jul 16 2012
    Mid-Atlantic
    I did the entire 034 kit and the ONLY extra NVH I've experienced has been a SLIGHT whine between 50-52MPH while on the throttle after installing the rear diff kit (transmission mount went on first). It's eliminated by either my intake or the radio. DSG shifts are amazingly smooth now. It's linear acceleration.
    Nothing against ECS (they're a f-----g amazing company that will continue to get my business), but as another poster put it, Eurocode and 034 both sell hardware kits when it's necessary. It looks like the ECS mounts are taller, which requires new hardware. I think that the whole "torque to yield" argument is more of a justification for extra parts in the kit.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by SteveYem View Post
    My car doesn't do this and I'm all stock diff/transmission wise. You sure it isn't something else?
    Jan 14 2015
    United States
    I have experience with using torque to yield bolts in design. Why do people use torque to yield bolts with torque+angle instead of just specifying a torque value? This is because they are trying to achieve a consistent CLAMP LOAD in the joint. If you just use torque, your resulting clamp load will vary quite a bit because many, many factors affect the torque application (thread quality, lubrication on threads, etc.). If you look at the torque vs. angle plot of a generic bolt, the torque increases to the yield point and the torque value flattens out for quite a bit more angle application until you reach the failure point. Audi also ensures that the bolt is placed in yield because bolts relax. If you are past the yield point in the torque vs. angle curve then some relaxation in the bolt maintains the clamp load because the torque vs. angle plot is mostly flat past the yield point. Lets say your threads are dry and munged up, you may put 30 N-m on it but not reach the yield point, any relaxation then results in a loss of clamp load. Not ideal. Its also possible that since the bolt is stretched, your new yield torque is 25 N-m. So you keep adding angle trying to reach 35 N-m but the bolt breaks at 25.
    I say all of this to say you CAN re-use torque to yield bolts but you are introducing even more variables into that resulting joint clamp force. At least use loctite to help combat the bolt relaxation a bit so you don't lose joint clamping force. And if you find yourself turning and turning the bolt, trying to reach X N-m, STOP!
    I'm not disparaging anyone that chooses to re-use bolts or the companies that recommend that course. It can surely be done and chances are you'll be perfectly fine. I just choose not to go that route.
    Engineering nerd rant over.
    Mar 21 2015
    Thanks for the education^
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Works2shoot View Post
    Just for clarification purposes we include Genuine OEM Audi bolts. With any of our engineered replacement parts we always take into consideration how it should be installed by the book. Meaning we will reference the Bentley Manual which is what the manufacture uses to repair your vehicle. This manual also tells you which bolts are TTY, which in this case are the ones we include.
    All else a side thank you for the support.
    Jason
    Jul 16 2012
    Mid-Atlantic
    Jason
    I was referring to the diff inserts originally, but the trans mount looked taller as well - I should have been more clear, didn't want to bump that old thread.
    Regardless, as I've said before, you guys are an industry leader with incredible customer service. So many vendors take things too personally or seriously.
    Oct 02 2006
    Wadsworth,OH
    No worries! If you really don't want the replacement hardware in a kit we offer you can always call in and have a Sales rep remove it for you. Extra hardware when installing new parts will never hurt. There has been a few times I've been mid install and either lost an important bolt/nut or something got damaged from removal which would make installation difficult or removal again nearly impossible.
    Appreciate the support!
    Jason
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    Jason
    Jason - do you sell a Bentley Manual for a B8(8.5) S4? I've been looking, but can't find any info that they've ever created one.
    Mar 21 2015
    Quote Originally Posted by Danny2323 View Post
    You can register here and pay for a day and download everything for your car.
    https://erwin.audi.com/erwin/showHome.do
    Mar 30 2015
    Cincinnati
    Nice! Thanks man
    Mar 21 2015
    Nice! Thanks man
    No problem
    Oct 02 2006
    Wadsworth,OH
    We do not. Doesn't look like ones available specifically from Bentley. The one we use is by ALLDATA. I just have a habit of saying Bentley Manual since that's what I've used for the past 10-12 years when working on Audi's
    More info on ALLDATA below.
    Click HERE
    Jason
    Jun 11 2014
    Pittsburgh
    yes, mine does this. 034 trans mount, diff carrier mounts, diff mount, x-brace, and street density motor mounts and nothing seems "connected" . crawling in traffic the other day in first and second was brutal.
    1552
    Aug 12 2013
    Lexington KY
    I got the insert from 034 but all the other bushings (rear diff, etc etc) from ECS. like a dummy, I tried to reuse the bolts on the insert and over torqued them. THe head popped off so I had to take the whole tranny crossmember support off to get to the broken bolt. Luckilly, as seems to be the case most of the time, I had a good amount of the broken bolt still hanging out. I used vice grips to spin it back out, put everything back together and used new bolts the second time around. I've not had a problem since. I'll tell you though, that's a really really shitty feeling when that bolt head pops off though. You literally begin thinking about all the posts saying 'don't reuse stretch to torque bolts' etc etc. It's amazing how many of the threads you remember right at that moment. I'm sure your install will go fine though re-using them. Just don't be a freakin' bone head like me and monkey torque the bolts down or you'll be remembering these posts too.
    Even with it breaking, it really wasn't that hard of a job ot get the old bolt out but it sure did heighten the 'pucker factor' for me.
    Best of luck.
