Results 1 to 19 of 19
    May 25 2011
    Norway
    How does the B8 2.0T s-tronic handle tuning?
    Seeing how K04s, F23s and even the mighty EFR are nearing maturity, more daily driver power is now easier than ever. But how does the rest of the driveline hold up with the level of power now available to us?
    Is there any for instance any experience with s-tronic transmissions at 300 whp? Is anyone in here running a tuned car with this transmission?
    Someone said the transmission in the 2.0 TFSI 211 hp is the same as on the S4, does anyone know if this is correct. In my opinion, it would be a great combination with a larger turbo because the quick shifts and keenness to use high revs would hide any trace of additional lag.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Someone correct me if I'm wrong, but I don't believe any U.S. Spec B8 ever had an S-Tronic option. Someone from outside the U.S. would probably have a better idea.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by adamazing View Post
    i thought they were tip as well .. but i think they changed after 2014??
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I thought all tips for the B8 and B8.5 were ZFs (6 and then 8). I didn't think S-Tronic was an option for our cars, US or ROW spec.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by jmeenach View Post
    According to Wiki, the UK and European markets received an S-Stonic variant as a selectable option. Not sure how long it ran for though.
    https://en.wikipedia.org/wiki/Audi_A4#Transmissions
    Transmissions[edit]
    In 2009, Audi announced the seven-speed dual-clutch S tronic transmission as option for A4 in UK and European markets.[45]
    All A4L models include Speed 8 multitronic continuously variable/manual transmission, except for A4L 3.2 FSI quattro, which includes Tiptronic automatic transmission.
    Volkswagen settled a class-action lawsuit in 2013 involving the failures of the CVT transmission in its Audi A4 and A6 automobiles for model years 2002–2006[46]
    Mar 17 2014
    Los Angeles, CA
    That's crazy. Learn something everyday! Guess a European member would be better suited to answer OP's question then.
    instagram
    Apr 26 2014
    San Diego, CA
    I wonder if it would even be possible to import and swap? I wonder if it would even be worth it? The 8 Speed ZF seems to be holding up pretty damn good.
    Senior Member Three Rings Mina08's Avatar
    Apr 30 2014
    Classic Mini, and lots of bikes
    Sweden
    Thats funny as i was going to ask if anyone has done an oil change on the s-tronic 7speed tranny, i could not find any post's on the s-tronic.
    2011 2.0 TFSI S-Line Avant/S-Tronic/Quattro/Quartz Grey/19"OEM RS5 Rotors/
    CFBSWheel/VCDS+Mods/XCL+Mirracast/LED/R8Coils/3.0FMIC/K&NFilters
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by Mina08 View Post
    For that info, maybe look at the S4 section?
    instagram
    Apr 30 2014
    Sweden
    Will do, cheers
    May 25 2011
    Norway
    Wow, I had no idea you guys don't get s-tronics.
    Oct 04 2015
    Sweden
    I run just south of 300whp with my 3.0TDI, around the 650nm mark. No issues so far, but then again - i dont launch at every intersection either.
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by kvitrafn View Post
    We do with the S4 mod
    instagram
    Aug 04 2010
    Queenz/Westchester
    Here's an option if you ever decide you need more power and you are Worried the Stronic can't handle:
    http://www.sspperformance.com/audi-s...h-package.html
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Really Don't think the dsg can handle the torque or is as robust.... Alot of s4 guys have had mechatronics issues...
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by hyperunion View Post
    I'm no expert, but the BMW 335s are running the same ZFs as our A4s, the new B9 S4s are running ZFs, the RS7 is running a ZF, and the DSG is getting relegated to the A4s on the B9 chassis. To me this says a lot.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by lettuce View Post
    Pretty much the same zf8hp55 in the 3 series.. And that's a turbo inline 6... Long term reliability seems like Audi is banking on the 8 speed for the b9 s4... I see well over 450 lbs torque rating for that transmission... Was very surprised they went with a new version of the dsg for plan Jane b9 a4 models... Audi doesn't expect the mass majority of buyers to increase their engine torque well over 300,lbs
    Established Member Two Rings dbv2's Avatar
    Mar 06 2016
    To
    So if I'm reading correctly, the b8 8 speed tip tronic transmission is coded ZF. Now I've been trying to figure out if my car has launch control. It should if I have this trans?
    May 25 2011
    Norway
    To be fair, the mechatronic issues have nothing to do with engine power. It's analogous to a broken shifter mechanism.
