As any LED enthusiast knows, replacing some of the light bulbs with LED counterparts is a pain on our B6s due to "bulb failure" errors that aren't easy to circumvent (esp. if you, like me, don't consider load resistor to be a good option). So I've been searching the Net for better solutions, and there appears to be a hardware mod for the electric switch unit (not sure about the specific unit name, but it's a separate box that contains solid-state switches for various bulb lines). Sadly, I didn't save the link and can't find it ATM, but it was something like cutting one lead on the PCB and soldering it to ground.
But recently I've been told that it's also possible to prevent any specific error from displaying through editing the ECU firmware. So, the way I see it, that's doesn't actually disable the bulb integrity check routine, but it prevents the error from being displayed on the screen.
Can someone confirm it's possible? If so, does someone has an instruction on how to properly edit the firmware to that end?
