changing some hardware on my setup, and don't have room for my catch can in my bay. It consists of a barb fitting to -12 AN fitting that plugs into the hose off the back of the valve cover, into a -12 line, and into a Moroso vented catch can mounted on the inner fender bracket. With this setup you will also need to remove, and block off the factory pcv valve.
The catch can could use some polishing up, but is fully functional. The catch can itself is also filled with course steel wool to help collect moisture, and oil. the line is in great shape, and I'll include a new AN barb fitting for the back of the valve cover. Asking $140 shipped as the supplies I used to make this were pretty expensive.
