Results 1 to 20 of 20
Thread: 265's or 275's?
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    265's or 275's?
    For my summer setup on the S6, I have 20x9 ET47 wheels. I'd love to go with 275's for maximum grip, but not sure if those will work/rub and if 275/35 or 275/30 would be the way to go. I'm VAGCOM lowered currently.
    Thoughts?
    TIA,
    Per
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by S4Per View Post
    Thoughts?
    TIA,
    Per
    You'll find a lot of members running 265 PSS's on 9" wheels on their A/S6's. Haven't seen many run 275's, but I think there are a few.
    Quote Originally Posted by Vol 4.0T View Post
    That's a pretty aggressive offset plus you're lowered but I still think you'll be fine with 275's. My strip setup is 285's and I have zero rubbing when I tested them on the street. Seems like I could go 295's or 305's without any rubbing. The 275-30-20's will be a little shorter than stock and the 275-30-20's a little taller than stock. Don't think it's going to make too big a difference one way or the other.
    Never seen anyone run 285's on a 6 body, care to post some pictures and wheel specs to benefit the community?
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Established Member Two Rings Mdavis1722's Avatar
    Jul 12 2015
    I am running 275/30 but my wheels are 21x9. Fast4DR S6 is running 285/30/21 with no issues.
    Senior Member Three Rings ///M Traitor's Avatar
    Feb 05 2013
    Thoughts?
    TIA,
    Per
    I currently have 275-35/20's on my 2013 S6 with Velos 20 x 10 ET 40 wheels. When hard in the turns, the outside front will rub slightly if you hit a bump. I've only heard it rub when lowered 10 mm from stock, and only when in the turns. The back never rubs at all, and the front never rubs when going straight.
    The tire rubs on the little fender liner portion that sticks out with the fastener in it. If you look right in the top of your wheel will you will see it.
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by Mdavis1722 View Post
    It becomes a lot easier when you're running RS6 front fenders and heavily modded rear fenders
    2014 S6 - SOLD
    Feb 17 2004
    2013 Audi S6
    Thanks all, very helpful.
    Quote Originally Posted by ///M Traitor View Post
    Do you believe that's the only area where it rubs? Sounds just like on the RS4, where you can simply remove that clip as the surrounding ones hold the liner in place just fine.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Mar 24 2016
    2010 VW Passat CC Highline
    Calgary, AB
    I have 275-35-20s on my A7. Not lowered. on Audi S-Line rims (see pic below). No rubbing.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    avish, the S7's fenders allow for a wider setup than the S6. I had a choice of ordering 275's for only $23 more than the same tire in 255, but opted for the 255 because I too am concerned about rubbing. I'm lowered 10mm via VAGCOM. I'm also assuming the wider tire will result in reduced MPG's, though that's a small consideration given the performance capabilities of the car.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Jun 11 2013
    is too small.
    So. Cal
    Same deal - I ran 21x9.5 ET30 with 265/30/21 and had some rub on the clip; I removed the clip on both sides and bent the tab up just a little for more more room. I'm running the same setup but with ET35 now and no rub, even with 15mm VAG-COM lowering. The fender liner stays put just fine.
    "Hauling ass > new car smell" -HeelBuff
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Aggressive??? This is a more conservative offset than stock. The wheel face will only be 4.35mm further out than the stock 8.5" wheels with a 45mm offset. Plenty of room in there !!
    I have two sets of aftermarket wheels. One is 20x9 ET 35 and the other is 20x9.5 ET39. Both have 265/35/20 Michelin PSS tires.
    You can fit 275 on a 9" wheel, but it is not optimal IMO. I would go with a 265/35/20 tire. The handling limits of this car are not even close to stressing these tires. In fact, if I were you, I would go with a 265 tire and run a 12mm spacer as well. Keep in mind also, that some 265 tires will be wider than some 275 tires.
    Here is a fitment shot of the 20x9 wheel ET35mm with 265/35/20. Lowered about 15mm.....
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Feb 17 2004
    2013 Audi S6
    Perfect. Thanks!
    Never forgotten:
    2002 S4 Stage 3 Tip
    Mar 24 2016
    Calgary, AB
    Quote Originally Posted by Brooklyn View Post
    My bad.. I thought the chasis and overall clearance with fenders etc would be the same for the S6 vs 7. Mine is an A7 though :) not an S7.
    Feb 05 2013
    I do think that the clip is the only point rubbing but I don't know how I could confirm that. Perhaps letting the air out of the bladder with the wheel turned?
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    I've got 265/35 on a 20x9 ET25. In the 31K miles I've put on this setup, I've rubbed in the front maybe 5 times. It only happens when I hit a big dip or bump in a sharp turn at speed. I'm currently lowered about 10mm via VAG. I would think 275 on an ET47 wouldn't be any worse than my setup.
    You can find some side profile pics here: http://www.robcheng.com/s6bbs/
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Feb 17 2004
    2013 Audi S6
    Well, 275/35/20's ordered. I'll report back how they work out. Thanks for all the info!
    Never forgotten:
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    I just listed a set of virtually new 265/35/20 PSS in the classifieds.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    May 17 2018
    2013 Audi S6 stage 3
    Florida
    Just curious how it worked out. I've been scouring the forums for clear answers on wheel fitment that will clear 275/35r20's. I'd like to confirm two things.
    1) On the OEM 20" wheel they will fit with no rub (inside or outside rub)
    2) What aftermarket wheel fitment would allow me to run them. I was thinking about 20x9.5 ET35, or a 20x9, I really don't like the stretched tire look...
    2013 Audi S6. Stage 3 in progress.
    Feb 25 2014
    Texas
    Have 275/30 on my 20x9 ET37 wheels, perfect fit and no rub
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    May 17 2018
    Florida
    Quote Originally Posted by Ze_Nardo6 View Post
    I think I'm going to go with the Michelin PSS in 275/35r20. Looking for wheels now, really just like the S7 20x9 off the 2014's and 15's. Maybe I'll find a set of take-offs for a deal. Have ordered custom forged before...not ready for that again.
    Feb 14 2018
    2005 Yamaha R1
    Minneapolis
    I am running the same size tire 275/35/20 on a 20*10.5 but on a S7 and the stretch is barely noticeable
