Results 1 to 17 of 17
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Coolant reservoir spewing coolant.
    My 3.0 has been spewing coolant after I park. I'll come back either after work or the gym and there is a pretty good puddle under the car. It is not over heating at all. The weird thing is, it doesn't do it consistently. Like every 2 days of driving. On friday I was in bumper to bumper traffic for hour and a half. Highest the coolant got was 227 degrees according to my torque app. This past weekend I replaced the reservoir and the cap. Still have the same issue.
    Thoughts?
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Are you sure it's coming from the expansion tank?
    Sent from my DROID Turbo 2
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by imnuts View Post
    Well when it started there was dry coolant right below the hole on the bottom of the tank. I'm pretty confident its coming from the tank. I did bleed the system an hour ago. hmmm
    04 B6 A4 USP 2.7t
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    ^This. Check to see where the leak is coming from. The expansion tank is pressurized where the coolant is up to temperature (so never open it up with warm engine!). Yours looks pretty new. Was it changed recently? If yes, check the hose connections and the seal around the cap. Grab a white rag/towel and go around the tank in sections and see if you can catch the leak in case there's a small crack. Is that just a plastic casting mark in the middle bottom of your tank in the picture?
    Jul 28 2014
    SACRAMENTO
    I posted saying that the problem was happening with the old tank and cap and with the new reservoir tank and cap. I bought the tank on friday
    04 B6 A4 USP 2.7t
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Check the coolant lines around the expansion tank, just because its under that area doesn't always mean its coming from that exact spot above, ask me how i know....
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Aug 12 2009
    Dirty Jerz
    I'd get a pressure test kit, pressurize the system, and then look for dripping. It could be one of the hoses connected to the tank instead. When I was loosing coolant, I picked up a kit from Harbor Freight for like $40 or so.
    Aug 26 2005
    Get a sample of the coolant and have it analyzed for the presence of dissolved combustion gasses in the coolant sample by a lube oil analysis lab, If there is combustion gasses dissolved in the coolant, then there is a head gasket leak over pressurizing the cooling system.
    If there is a Caterpillar heavy equipment dealer near you, they usually have an analysis lab,
    The reason this symptom only happens after parking, is because after turning the engine off, the coolant temp actually increases due to the coolant absorbing heat from the massive engine parts and with the coolant flow stopping with the engine off, the coolant gets hotter before it gets cooler. If the cooling system is already pressurized more than normal, additional heat absorption by the coolant will raise the system pressure above the over pressure relief opening set point point of the tank cap.
    Vorsprung durch Technik
    Aug 13 2015
    NS
    Quote Originally Posted by 19jdog View Post
    Oops, sorry, I overlooked that. I hope you'll be able to track this down with the other excellent advice here.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Thoughts?
    227 degrees is too hot.
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by crazyquik22023 View Post
    I don't know about that! Driving to work on a cool morning, temperature is at 206-208 degrees 20 degrees warmer is too hot???
    Sent from my SM-N910P using Tapatalk
    04 B6 A4 USP 2.7t
    Jan 03 2008
    Richmond
    Probably. The thermostat opens and the fans come on at 212F so you shouldn't get much above that and only for short durations
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    those expansion tanks fail regularly. i went through 4 of them in 10 years.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Aug 27 2013
    Philly
    The 3.0 runs hot. Its just the nature of the engine. Our coolant temp also reads at one of the hottest points in the system.
    Sent from my Nexus 6 using Tapatalk
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by eljay View Post
    No worries!
    I think its the thermostat. Over heated on the way home from work. Limped her home waited for her to cool, then put more coolant in her while she was running. Bled the air out of system, took her out for a jaunt. So far so good. I will be replacing the thermostat this weekend though! This is getting annoying
    04 B6 A4 USP 2.7t
    Aug 27 2013
    Philly
    No worries!
    Hmm. Generally when thermostats fail, they fail in the forever open, right? Thats what I've always been told at least. [IMG][/IMG]
    Aug 26 2005
    No worries!
    T-stats never fail closed due to the way the stat is designed to function
