Results 1 to 15 of 15
    Sep 04 2014
    San Francisco
    Akebono pads on S5
    Has anyone installed Akebono pads on S5? I know they are better for dust but does it affect the stopping distance? especially in combination with Zimmerman rotors.
    Veteran Member Four Rings LAXlittleant26's Avatar
    Nov 26 2014
    PG County, Maryland
    Quote Originally Posted by Ari1982 View Post
    I have them installed on my '13 S5. It felt like the stopping power was better when compared against stock pads against stock rotors but I don't have the stats to back that up. I've also never run Zimmerman rotors.
    2 cents. Hope it helps.
    Aug 06 2015
    Colchester CT
    I have the Akebono pads on my 2016. As on my S4, feel weaker at first, then better over time. No stopping distance comparison.
    Way better than stock for dust!
    Established Member Two Rings Churchill's Avatar
    Jan 20 2012
    Westport, CT
    I have Akebono Euro ceramic pads on my car. I've used them for about 6 months and can recommend them. Far less dust and stopping seems to be as good or better than OEM.
    "He has all of the virtues I dislike and none of the vices I admire."
    2010 S5 Cabriolet Phantom Black with Atlas Carbon Fiber trim | 50% tint|SmartTop|APR Stage 1 ECU|AWE Touring exhaust|Brake Performance slotted & dimpled rotors | Akebono Euro Ceramic pads|PIAA yellow fog bulbs|Debadged V6 T front wings and rebadged with "Supercharged" carbon fiber | LED interior and license plate bulbs.
    Apr 11 2012
    Langley B.C.
    I've had mine for around 2 months now. At first it felt like it needed about 10% more foot pressure on the pedal, but now it's normal. The lack of brake dust is fantastic.
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Quote Originally Posted by Churchill View Post
    Quote Originally Posted by Liquid99 View Post
    Need the pads to heat up more. That's why there seems to be less initial bite.
    Very common.
    I use these ceramic pads on my 10 S5. no problems here. Even tracked them.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    I love mine as well. Switched from Hawk. The breaking feel is more consistent through the entire pedal distance. They seem to be easier on rotors, where as the Hawks ate my ECS rotors previously. Not sure if that was an ECS or Hawk issue, though I never had the issue on the past with Hawks and other rotors.
    Low dust, good feel, and no fade. I love these pads.
    Veteran Member Four Rings diego_demarco's Avatar
    Feb 13 2014
    Ft Lauderdale
    Is it hard to install these yourself on the front brakes? Just received my akebono front pads in the mail but I'm wondering if I should have a shop do it!
    2013 Audi A5 Cabrio! Vossen CV7s, ecs tuning carbon fiber intake, Xenonz RS5 front bumper, Apr stage 1!!
    Audis of South Florida car group!
    Follow us on Instagram
    Veteran Member Three Rings Mr. Spectacular's Avatar
    Nov 08 2013
    Houston, TX
    i have the ceramics. my rims are 1000 times cleaner. that was my main motivation, but the bite seems fine as well!
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    I put the Akebonos on my 2014 S5. The initial bite when cold goes down a bit and overall IMO the braking experience becomes more linear. You press harder, you get more, very predictably. Leads you to press a bit harder for the first 1/3 of stopping power to stop like OEM but once past some point, it's all about the same.
    It took me a few days to get used to it. Now I don't notice it at all. I does brake a lot like my wife's 03 Camry which has the same type of pad on it.
    Does seem pretty easy on the rotors too.
    FWIW I just threw the pads on without touching the OEM rotors at around 10k mi and no issues at all.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Feb 13 2014
    Ft Lauderdale
    Did you guys apply any lubrication to the pads? I've had my posi quiet pads and ecs rotors on for about 5k miles now but I'm tired of the dust so a buddy of mine is installing the akebonos tonight
    Jan 27 2010
    Cayenne%20X5
    Long Island, Queens, LA
    they are worth it for the reduced brake dust alone.
    the only thing i don't like about them is the reduced initial bite vs stock pads. i'm not sure about overall stopping power but i'm sure it's similar if not the same as oem.
    ig: gs.autogram
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Quote Originally Posted by diego_demarco View Post
    Yes. Always lube up the metal to metal parts without going crazy. Less lube = better.
    2011 335xi (gone)
    2008 335xi (gone)
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Quote Originally Posted by GSS5 View Post
    Agreed. The brakes feel a little less "sporty" and more like my wife's Camry after the pad swap. But given how much I hate cleaning my AG M590s, it was definitely worth it. I don't really notice the difference in brake feel any more.
    2011 335xi (gone)
    2008 335xi (gone)
    Aug 18 2013
    Indianapolis
    Fronts are easy, lots of writes ups and very straight forward. The pistons can be pushed back very easily.
    The rears are a little more complicated, but easy if you have a VAG and brake piston tools.
