Results 1 to 4 of 4
    Feb 29 2016
    Bellevue, Ia
    drivers door not unlocking
    Anyone ever have an issue with the drivers door not opening when hitting the unlock button.
    What could cause it?
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    Door lock actuator. Happened on my A6
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Feb 29 2016
    Bellevue, Ia
    And the fix is? Expensive some gaston do I can do it?
    Established Member Two Rings INDY-S5's Avatar
    Jul 25 2013
    2011 Shelby GT500 SVT, 2012 Ford Edge, 2004 Audi S4, 2006 Honda Shadow
    Indianapolis, Indiana
    Quote Originally Posted by pchrist View Post
    I had a similar issue, my fob would lock/unlock all doors except for the driver one. I initially thought the actuator was bad to the driver door since the car would lock/unlocks all doors but not the driver door and it would not set the alarm either. I looked at the wire harness between the body and door and found that a wire was broken and it happen to be the one causing the issue. I repaired the bad spot and everything worked fine from there. Just something else to consider looking at if you do not find the issue elsewhere and the wires in that spot are know to break and cause issues. A new harness is roughly $150 but I was able to just repair my one wire and did not need to install a new harness entirely.
    Good luck.
