Results 1 to 6 of 6
    Established Member Two Rings NorthWestB8's Avatar
    Jan 03 2016
    Renton WA
    VMR V701 19x9.5 with Toyo Tires - No Longer Available
    I have a set of gently used VMR V701 wheels with tires.
    Wheels are 19in x 9.5
    Offset is ET45
    Bolt Pattern is 5x112 (Mercedes, VW, Audi, fitment)
    Weight is 25.5lbs per wheel
    Centerbore is 66.6 so you can run them on any 5x112 audi esentially provided you use hub rings on 57.1 spec cars.
    Condition is a good 8.75/10 one wheel has a little bit of road rash but nothing big was quoted 60 bucks to repair it if wanted.
    I drove these as my back up winter set. Tires are in good condition with probably 20K left on them.
    Not looking for trades really unless you have something wider like an 18x10 or 19x10.
    List Date: 3/28/2016
    For more info, click here to view the original listing: VMR V701 19x9.5 with Toyo Tires
    This item is no longer available.
    | B8 2.0T | APR Stage 1 | VMR V701 19x9.5 | 15% Tint | AFE Intake | 034 Test/Catless Pipe | Resonator Delete | RS4 Grille | OSIR CF Hood |
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    I can ship these for you guys if needed, I'm a contractor for FedEx so it'll be much less than standard rates. Shoot me a text if you need my help (309)370-2657
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Jul 23 2015
    Montreal canada
    265-30r19 tire if i see well lot of tread left?
    Jan 03 2016
    Renton WA
    Quote Originally Posted by Petatew View Post
    Yeah I'll get a photo of tread depth today.
    Jan 03 2016
    Renton WA
    Bump!
    Jan 03 2016
    Renton WA
    Bump! Will ship anywhere and split shipping costs.
