Results 1 to 25 of 25
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! ECS Transmission Mount Bushing Insert Kit
    Our new performance transmission mount kit will Harness the Power of your Audi Engine and Transmission through Advanced Design Methods and Materials.
    ECS Tuning's Performance Transmission Mount Bushing Insert Kit offers a more engaging driving experience, with crisper throttle response and reduced driveline slop without increasing cabin NVH.
    The most experienced enthusiasts have learned that an engine that is routinely pushed past the factory-specified stress and flex tolerances requires special accommodations in order to operate consistently at and past the limit.
    Features include:
    • Reduction in transmission movement
    • Melonite coated steel backing plate for increased durability and corrosion resistance
    • Polyurethane bushing insert to reduce drivetrain deflection while keeping noise vibrations associated with such modification to a minimum
    • Increased drivetrain rigidity and response
    • Long-term testing performed on multiple vehicles for real-world qualification
    • Included hardware to replace the factory torque-to-yield bolts
    Insert Rigidity & Response
    Fits:
    Audi B8/B8.5 A4 2009-2016
    Be sure to check out our -----> Installation PDF <-----
    ***Requires M10 triple square socket for bolt removal*** Click HERE
    Jason
    Jan 28 2006
    connecticut
    Has anyone purchased this? Looking at either this one or the 034Motorsports transmission insert. Thanks
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by srt-4 killer View Post
    Just ordered one today!.. well see how this compares to the solid billet 034 one... Expecting minimal vibes compared to the 034 one... Free shipping as well...
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Three Rings callaghan.'s Avatar
    Apr 08 2009
    Installed one 2 weeks ago on my '13 allroad - already have 700+ miles on it. No vibration, and I do notice better response for sure. Good addition for the price! And only took a few minutes to install.
    avantlife.
    Jan 28 2006
    connecticut
    Thanks for the replies. Just ordered the Ecs one, I'll give some feedback when I get it installed.
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    This looks intriguing. Anyone else have feedback? Will it work with the 8 speed AT?
    Can a noob like me install this himself? (full disclosure, I have a basic set of tools and can change my own oil and can swap out my own seasonal wheels)
    Dave
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    Quote Originally Posted by hyperunion View Post
    would be interested in a comparison between the two...i have the 034 right now, and am not liking the amount of vibes...if this is significantly less, i may jump on this.
    Oct 02 2006
    Wadsworth,OH
    This will definitely not transfer as much NVH as a solid insert due to the poly construction. It's a very simple install, you just need to be sure you grab the M10 triple square socket otherwise you wont be able to take it out. Its listed in the original post.
    This mount fits both manual and automatic transmissions.
    Jason
    Apr 17 2014
    MA
    ok i ordered this and will give it a try. hoping for a noticeable improvement.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by kdaffy View Post
    Thanks for the order! Feel free to leave some feedback in this thread when you get it installed!
    Jason
    Jan 28 2006
    connecticut
    Installed it over the weekend and it literally took 2 minutes. Jacking up the car was the worst part. The car feels great, shifts feels more firm there is no added noise from it and acceleration and deceleration feel way better. Definitely worth the money!
    Sep 03 2012
    Lehigh Valley, PA
    Look forward to see how this works.. just got mine in yesterday!
    Feb 15 2016
    Oak Lawn IL
    are you really experiencing that much vibration? i currently have 034 street density motor mounts, street density trans mount and there Billet Aluminum Transmission Mount Insert insert along with both Billet Aluminum Rear Differential Mount Insert (Front) and Billet Aluminum Rear Differential Carrier Mount Insert (Rear) and have minimal vibration when cold but only at idle the moment i start moving all vibration go away. after a mile or 2 when the engine and drivetrain are complete warm all vibrations go away completely even at idle.
    Apr 17 2014
    MA
    Quote Originally Posted by kpr478 View Post
    I am experiencing incremental vibration, and its annoying...whether its "that much" I dont know, but its annoying. It became noticeable right after the install of the 034 drivetrain mount package (trans mount and diff mounts)...my wife noticed it immediately after install when i parked at a coffee shop and ran in while she was in the car with the kids.
    Now, maybe by coincidence, when I had these installed, my engine mounts started to deteriorate (although I havent seen any fluid and they look OK upon inspection, but what do I know), but the timing of everything leads me to believe its the 034 kit. I wouldnt have any problem with it were just me, but I have to think of the wife and kids...its most noticeable at red lights, idle, parked...yes its worse when cold, but doesnt get materially better once the car has warmed up.
    I'm going to try the ECS version, and also am getting my engine mounts professionally checked just in case I'm putting blame in the wrong place.
    Out of curiosity, do you have automatic or manual transmission?
    Feb 15 2016
    Oak Lawn IL
    i have a 2010 A5 2.0T Quattro with a 6spd manual but since the a4 and a5 are basically identical and the a4 community is a lot bigger i spend most of my time on this side
    Apr 17 2014
    MA
    That's what I thought...I think 6mt experiences less nvh than auto
    Sent from my Nexus 5X using Audizine mobile app
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    Just placed my order on Friday, stoked to get it! Has anyone else installed recently and have any input?
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Installed mine last night on my DSG. Very very easy. Only issue was not having the correct star pattern bit to remove the OEM bolt. Used an allen wrench to get it off without any issue. Glad the kit comes with a more standard allen wrench bolt for the install. Notice a little smoother shifts, but I havent drove it hard yet.
    https://www.ecstuning.com/b-ecs-part...DXfhoCH8_w_wcB
    I'm as cool as a cucumber in a bowl of hot sauce.
    Oct 02 2006
    Wadsworth,OH
    Thanks for sharing your feedback!
    Jason
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    would this make any difference on a CVT?
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Aug 17 2015
    California
    I finally got mine a few days ago after over a month of backorder. It's ok because I got 25% off with the ECS holiday sale.
    Excited to install it, maybe tomorrow. Will report back after install and a week of test driving. ZF8HP.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Quote Originally Posted by JeriQo View Post
    I notice a little difference, not much.
    Oct 02 2006
    Wadsworth,OH
    CVT isn't going to make as massive of a difference as you're not physically connected with the shifter (where most people feel some of the difference). But is is going to ad rigidity to the driveline eliminating some play so as BeerBrent said, you'll still feel a little difference.
    Aug 17 2015
    California
    Installed this in my 8 speed tip last weekend. Install is super easy, the hardest part is jacking up the car and making sure it's safe before you crawl under.
    I definitely notice a positive difference when driving. Shifts are a little bit crisper and I feel a little more connected to the road overall. There is a slight, very slight, increase in NVH when I'm sitting at idle. It is just a little bit of added vibration. Overall a positive improvement to the driving experience.
    Oct 02 2006
    Wadsworth,OH
    Thanks for the great review A4x!
    -James
