I've been a long time lurker on here and I've had my b6 a4 for close to a decade now. I caught the mod bug after going with a F21 Frankenturbo to replace my aging k03.
Now i'm finding myself in the process of acquiring parts for an engine build. My power goal is around 400awhp.
So far I have a spare 06A short block and I've purchased a fully built AMB head.
The head has:
Integrated Engineering Street/Strip Camshafts
IE Titanium Valve Spring/Retaining Kit
IE Valve Stem Seals
IE Valve Guides
Ferrea Intake and Exhaust Valves
As far as building my block goes, this is what I currently have as a parts list:
AEB pistons
OEM piston Rings
IE rods w/ rifle drilling option
IE Rod install kit (head gasket, etc)
Mahle rod/main bearings
ARP studs/bolts
New oil pump/chain/pickup tube
having the rotating assembly balanced and the block honed/decked and the head leveled
For my power goals, do you think the IE engine girdle is overkill?
Should I get billet main caps?
Is there a benefit to going with coated bearings as opposed to non?
Would there be any substantial benefit (considering my power goal) in going over-sized aftermarket pistons instead of B5 AEB ones?
Is there anything I'm missing as far as parts that I should be thinking about for the engine build?
I haven't even begun to do in-depth research about the turbo that I will eventually pair with this set up, but i'm thinking an EFR variant of some kind with an RAI manifold.
A stronger clutch is a given.
