Our new performance transmission mount kit will Harness the Power of your Audi Engine and Transmission through Advanced Design Methods and Materials.
ECS Tuning's Performance Transmission Mount Bushing Insert Kit offers a more engaging driving experience, with crisper throttle response and reduced driveline slop without increasing cabin NVH.
The most experienced enthusiasts have learned that an engine that is routinely pushed past the factory-specified stress and flex tolerances requires special accommodations in order to operate consistently at and past the limit.
Features include:
- Reduction in transmission movement
- Melonite coated steel backing plate for increased durability and corrosion resistance
- Polyurethane bushing insert to reduce drivetrain deflection while keeping noise vibrations associated with such modification to a minimum
- Increased drivetrain rigidity and response
- Long-term testing performed on multiple vehicles for real-world qualification
- Included hardware to replace the factory torque-to-yield bolts
Insert Rigidity & Response
Fits:
(Audi B8 S5 2008+)
Be sure to check out our -----> Installation PDF <-----
***Requires M10 triple square socket for bolt removal*** Click HERE
Jason
