I bought a complete 03 donor car to do my swap, and yes my CVT was toast. TCM replacment 5months ago $$$ and now Clutch pack fail.. I'm done with it. The car is in very good condition with just over 101K.
Question is : I have not seen anybody do a swap to a Cabby, is there anything I should be on the lookout for or aware of.
List of what I have taken off the donor car or bought recently.
5 spd FPS FWD trans
Shifter assembly
full pedal set with switches
Axels
New trans mount - do it while it's out
New rear main - again do it while it's out
New Valeo Clutch, Pressure Plate and SMFW
Genuine VAGCOM Hex+Can
have the clutch hardline, but bought a USP for ease
Doing Motor Mounts and Snub mount for GP as well.
I actually have the ECU and Wiring harness from the donor, but I would rather just add the reverse light than replace the whole harness and VAGCOM the ECU from CVT to Manual..
As of last night I have removed:
Cat and exhaust
Oil Lines
Axels
Center console
Pedals
CVT Shifter
and I have 7 bolts cracked loose
