From what I know my car is all stock, when accelerating from low rpms in a higher gear my boost gauge will run up to 15-18psi then drop off and hold a steady 9-10psi. But when accelerating from higher rpms such as 3k in 5th gear it will only boost to the typical 9-10psi for a stock car. when I got the car the guy that had it said he had a apr stage 1 tune on it, but said he took it off because it wasn't running right, so im not sure if the tune is still there or not. Could my waste gate be out of adjustment or what could be going wrong? I haven't ran any logs to see requested vs. actual yet because my battery on my laptop bit the dust and it must be plugged in at all times for the computer to stay on
Any help would be greatly appreciated before I go insane and just sell the damn car, because my temperature flap on the driver side is stuck and wont readjust with vagcom, I have a coolant leak from somewhere, boost leak from under the intake manifold, and also my ac pump exploded(hopefully the one on my parts car is okay) so I have a long list of things that need attention.
