Results 1 to 2 of 2
    Senior Member Two Rings Quartz05's Avatar
    Dec 30 2005
    2010 A4, 2007 9-3
    Englishtown, NJ
    Stupid Inspection Reminder - Go Away?
    I opted not to pay the local dealer for my 15k "inspection" and had the actual work (oil change, cabin filter, etc.) done at my local lube shop.
    So they reset the Oil Change reminder, because you can do that in Car Settings. Apparently, however, you can't do that with the Inspection reminder.
    So... Do I absolutely need to spring for VCDS to do this, and - what's everyone using these days? Back when I had my B7, everyone was using Ross-Tech.
    Former:
    2005.5 A4 2.0T QM
    APR 93
    Current:
    2015 A3 2.0T
    Unitronic Stg1 ECU/TCU
    2017 VW Sportwagen
    Feb 13 2015
    VA
    You need VAGCOM/VCDS for it. I had a buddy with it reset it and set the counter for it to 60,000 miles or whatever the max is so I won't have to deal with it for a long time.
    2015 S3 - Revo Tuned
    2016 SQ5
    2008 F350 - Pistons/Cam/Studded/Deleted/Single Turbo
    2010 GT500 - Twin Turbo
