Results 1 to 4 of 4
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    2000 AUDI S4-STAGE 3-AIRLIFT PERFORMANCE/V2 - No Longer Available
    I have owned this car from March 2008-present. Car has every option from the factory aside from sport package. Factory Nav and all.
    I purchased the car from a 60 year old gentleman whom was the original owner, bone stock, with 35k. Since then,I have completed many many many service/maintenance requirements such as timing belt/ water pump, valve cover gaskets, half moon seals, wheel bearings, and many other preventative maintenance requirements over the course of the years, all is documented. Car currently has 129k.
    There is too much info to list about the car, please email for more information/details regarding maintenance / any other questions any party interested may have.
    Performance:
    -Custom F21 Turbos/VAST inlets/OEM hardware
    -Bosch 044 Fuel pump
    -3" JFR Down pipes
    -3" custom Vibrant cat back
    -Vast Stage 3 Clutch
    -JHM FMIC
    -034 2.0T conversion/ICM delete
    -Custom intake
    -FT diverter valves
    -RS4 MAF
    -Siemen Deka 60lb injectors
    -Bosch 3 bar FPR
    -Snow Performance Stage 2 Water Methanol System/adjustable start spray 8psi/full spray 18psi.
    -Stern Street Transmission mounts
    -Stern Street Motor mounts
    -Upgraded diff bushings
    -New Red top Ultima
    ****This car was tuned by one of the best professionals in this industry, many hours went into tuning this car, Sean aka DonSupreme. The car is on 25lbs of boost/475whp/500wtq.
    Suspension:
    -AIRLIFT Performance Air Ride Kit
    -AutoPilot V2 Digital Management
    -Skinny 4gal tank/ custom trunk platform
    -440cc compressor
    -HD control arms/bushings
    Exterior:
    -Professionally resprayed hood, front fenders, front bumper, and rear bumper in the past 6-12 months.
    -Stoptech ST40 front BBK, new rotors and pads
    -ECS drilled/slotted rear rotors/ ECB red stuff pads
    -OEM RS4 grill
    -M3 lip spoiler
    -15/20mm spacers
    -color matched front euro tag
    -3 sets of wheels, Porsche RH reps, 2 sets of Audi wheels.
    -LED tag lights
    Interior:
    -Kenwood Nav head unit
    -UUC short shifter
    -JHM cross rod upgrade
    -Delrin bushings
    -25th Anniversary S4 shift knob/boot
    -AEM wideband
    - Boost gauge
    -Hands Free Parrott Bluetooth system
    Thank you in advance.
    15,000
    List Date: 3/27/2016
    For more info, click here to view the original listing: 2000 AUDI S4-STAGE 3-AIRLIFT PERFORMANCE/V2
    This item is no longer available.
    Feb 03 2008
    At work
    and up
    Feb 03 2008
    At work
    and up
    Feb 03 2008
    At work
    bump
