Results 1 to 3 of 3
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    Possible to get air into the clutch system?
    Hey all, I've had an issue with my clutch for the past year or so. Occasionally after a WOT pull through a few gears, or if I rev the motor quickly while rolling my clutch pedal only returns about halfway. I can pull it back up and it works perfectly. No slippage or any others issues, but I am curious if its possible that im getting boost into the lines because this only occurs after a hard pull. I remember reading a post(that i cannot find) where someone was explaining that its possible for a certain check valve to go bad, and then allow boost to get into the clutch line causing the non-returning pedal. If anyone has experienced this or has an idea Id appreciate your input! Thanks.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    A leaking clutch master will suck air into the lines. No correlation between boost though.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    I have the same symptoms and I have come to the conclusion of it being my clutch master cylinder
    Sent from my SGH-M919 using Tapatalk
