Results 1 to 3 of 3
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    Looking for confirmation of a P/N
    On my 2001 AWM engine there is a hard line connected to the Kombi valve. At the hard line end closest to the front of the car, there is a 90* rubber connecting elbow. Mine is split Does anyone know the correct part number for the rubber elbow?
    Thanks
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Established Member Two Rings j-dells's Avatar
    Feb 09 2016
    Minnesota south suburbs
    You shouldnt need a part number. Take your broken piece and go to the auto store or maybe a hardware store and find an elbow hose that is the same size. things like this dont have to be oem. On my S4 I replaced all the hard plastic hoses (spider hoses) with a rubber hose from home depot. Works great!
    Also the hard plastic hoses are a huge bitch to deal with. they break soo easily especially when they are cold. I was forced to replace them because i cracked one when taking my pancake valve of... oops.
    2002 B5 S4 SRM ko4 hybrids Stage 2 eBay tune at 21 psi
    2000 Grand Prix GTP Def not stock (Rod bearings... awkward)
    May 16 2008
    WA
    /\ you have to be careful doing that though, as lots of hoses are not rated for petroleum contact. So just keep that in mind depending on the hose's intended purpose.
