Results 1 to 10 of 10
    Established Member Two Rings ecjr173's Avatar
    Aug 08 2008
    05 A4 1.8T S-Line
    Oil Pan Replacement!!
    Hey guys,
    So i noticed little drops of oil in my garage when i moved my car. Got under the car and saw what appeared to be a hairline crack. I wiped the oil that was present and came back 10 minutes later to check it. Well sure enough there was a little bit of oil forming at the crack. Is there a DIY for replacing the oil pan on a 2005 B6 A4. Any info would help. Oh and yes i did look in the DIY section but didn't see anything.
    05 A4 1.8T S-Line
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Unfortunately the picture links no longer work but there is still a lot of good info in the thread: Clicky click® Here's one with pics. No need to discharge the A/C. Clicky click®
    The best one by far: Clicky click ®
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Quote Originally Posted by ecjr173 View Post
    Hey guys,
    It's not that bad a job. Had to do my pan pull to replace my oil p/u a month or so ago but it was w/ the engine out.
    Have you considered a weld bead? or maybe a JB Weld repair, Quick Steel? I know those are not real repairs like the pan replacement but would save you some labor if you were to pull it off successfully.
    I'm just thinking out loud feel free to flame on.
    Apr 15 2014
    Ottawa/Gatineau Canada
    Nothing to loose with a quick sand (to give a tooth to the epoxy) and then application of some JB weld...you have nothing to loose except the 5$ for the JB weld ;)
    Sand a few inches away from the crack and apply JB weld said few inches from the crack. I would suggest a putty stick version of JB weld as opposed to the traditional 2 part epoxy that mixes like pudding until it starts to harden.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 05 2007
    I agree with the above. For a hairline fracture, I would go the JB route. It really isn't worth the hassle for such a small leak. Or try a metal filler.
    Aug 08 2008
    05 A4 1.8T S-Line
    Yea I saw a Jb Weld repair on YouTube. I think I'm going to go this route cause it's a very small hairline crack. So the sanding portion is for adhesion purposes correct. Which is best the 2 part epoxy or the putty stick version.
    05 A4 1.8T S-Line
    Aug 20 2012
    Mesa, Az
    I bet any of the name brand stuff would keep it sealed up fine. Most important is the prep that you do prior to applying the epoxy etc. Personally I have had good success w/ the quick steel in a single tube. Used it to repair damaged threads on the block of a Nissan p/u to seal up the water pump. That was like 5 years ago and still no issues to date.
    Apr 15 2014
    High heat KB weld, stick
    Jan 06 2009
    It is a cast aluminum pan. Any residual stresses in that pan coupled with heat cycling will cause that crack propagate. The jb weld may stop the leak for now however the crack will likely grow resulting in a massive leak when you least expect it. Just replace the pan... it is cheap in comparison to replacing your bottom end when that crack splits while at 60mph.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Apr 15 2014
    Quote Originally Posted by ADCS View Post
    Well, this makes sense.
    You also get to clean out your oil pick up tube while the pan is off ;)
