Results 1 to 9 of 9
    Established Member Two Rings DangerBruno's Avatar
    Apr 15 2014
    01’ allroad
    Scranton, PA
    B8.5 allroad steering.
    So I've had my allroad for almost 2 months and I'm about to start getting into modifications (will start a thread once I get going) and I'm noticing the steering is very strange. Now I know that the electronic steering is obviously going to feel different than the normal system I'm used too but I feel like it's not right. It's almost like going straight is difficult, as if the car wants to always be "floating" in between the lines. Now I read that going "lock to lock" before you drive helps and I think it might be, but is there any remedy to this? My allroad just crested 50k so I believe my warranty is out. Will my dealer do anything for this? Is there a potential recall on this? What can I do to help remedy this if anything?
    Aug 06 2012
    Parker, CO
    What year is your AR?
    There was a TSB for a software update that fixed many AR's with this problem. Some of us early adopters even has steering racks replaced.
    Apr 15 2014
    01’ allroad
    Scranton, PA
    Quote Originally Posted by treginginco View Post
    It's a 2013
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Quote Originally Posted by DangerBruno View Post
    It's a 2013
    Mine has 97k miles and has always been like this. The steering is just shitty. You're lucky you don't have the notchy steering issues they had... That SUCKED
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Nov 27 2011
    08A8 swb;2013 allroad; 2005 C5 allroad; 1972 Ford Ranchero; 1967 Triumph TR4 with 300 Ford inline-6.
    cincinnati, ohio
    Just make sure your car has had the steering rack software update done. That part should be free. Since they did that update on my wife's allroad, the car has steered perfectly for the past two years!
    Your "darting about in a straight line" is exactly the problem the Recall-update addresses.
    Apr 15 2014
    01’ allroad
    Scranton, PA
    Quote Originally Posted by Ivonius View Post
    So I can just call my dealership and ask if they will do it? Or is this something I can do with vagcom or a local shop? My nearest dealer is 50 miles away and they are f@$ing useless there tbh.
    Aug 06 2012
    Parker, CO
    This is a dealer installed software update. It cannot be done by VAGCom.
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by AllroadCorbin View Post
    My 2013 Allroad is just the opposite; I can let go of my steering wheel and it'll hold true for quite of bit of time.
    But mine did have the steering rack TSB service completed.
    Tire selection and alignment also play a large role in steering wheel true-ness.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Established Member Two Rings ATL_wagon_guy's Avatar
    Jan 08 2016
    2013 Audi Allroad, 2009 Volkswagen Passat Wagon 2.0T
    Decatur, GA
    The steering in mine is similar. It's almost as if it wants to go down the sides of the road crest sometimes. It's not unmanageable or anything, just annoying.
    I read about the steering issues for early ones (mine's a 2013 as well) and had the dealer check it out as the warranty was still active. They said that the software and rack were up-to-date. So, I think the next step is to get a VAG-COM cable (or a local forum member who does) and activate the ADS. That should at least give me the ability to add some resistance to the steering if I'm understanding the forum posts correctly.
