Finally decided that the cars gotta be dropped.This is as result of lusting after a set of dished Alzors in 18" by 9"-349's.My current setup is 18 by 8's ET43 sitting on S-line suspension.Doing the math for these Alzors at ET 35 and 9 inches wide,I hope most of you agree the width increase would then be ~21mm ( 8mm ET diff and 12.5mm being 50% of width increase )
My front fender inboard clearance is now 10mm so the poke would be around 10mm or 3/8th of an inch.Yep,not good.So the suspension question:if I used say ST coilovers would the fact that I could drop the car another 1.5 inches, be enough to increase the negative camber and pull the wheel/tyre back in to flush ? Would the increase in wheel width also change the camber to help me ? Opinions please.
