Results 1 to 10 of 10
    Oct 02 2005
    The Moon
    Airbag question for Avant rear seats.
    I'm trying to remove my rear seats semi permanently and I discovered there is an airbag connection that goes into the wider fold down portion of the seat. How can I unplug this and still maintain the airbag system, and not have the airbag light on the dash?
    Appreciate any guidance.
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Unplugging any airbag will turn on the airbag light on the dash next time you turn the ignition on.
    To prevent this you will need to fit a resistor in place of the airbag.
    Oct 02 2005
    The Moon
    Quote Originally Posted by PetrolDave View Post
    I understand it will trigger the light. Hence the post.
    I'm asking what is the solution, what ohm resistor would I use for this airbag?
    Thanks
    Jan 14 2007
    Hampshire, U.K.
    I did a Google and it's not clear what value resistor you need as it seems to depend on many factors but it looks like it's somewhere between 2 and 3.3 ohms.
    Oct 02 2005
    The Moon
    Thanks for the help.
    Here is a pic of the one I'm referring to. Is this an airbag in the seat or a sensor? Don't see why it would be on the 60 portion of the fold down and not one on the 40 side.
    Bottom left hand corner.
    Jan 14 2007
    Hampshire, U.K.
    If there's an airbag in the seat it will be a side airbag, so somewhere on the side of the seat will be a small plastic "airbag" badge as a warning that there's an explosive device in the seat.
    Oct 02 2005
    The Moon
    No airbag badge on the rear seats. So what is it?
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Occupancy sensor?
    Old Geezer, formerly known as Stud Muffin
    Oct 02 2005
    The Moon
    Quote Originally Posted by QIKRNU View Post
    Occupancy sensor?
    That's my guess, but why only have a sensor on one side of the rear seat? The other isn't connected in anyway.
    I just want to get these out without an airbag light.
    Jan 14 2007
    Hampshire, U.K.
    Sensor for seat fully locked in upright position for seatbelt warning light?
