Results 1 to 21 of 21
    Mar 26 2016
    West Midlands - Staffordshire
    10' A4 B8 SLine Lowering onto 19" OEM Peelers
    Hi there,
    Im wanting to essentially lower my b8 on 19" peelers, lowered enough to look sporty but not impractical. Ive been looking at H&R sport springs and 19" peelers for a while now but i just want to double check one last time before i jump in.
    Would 30mm H&R sport springs on 19" peelers but a good combination? Could someone throw some pictures up to show me good examples if possible, I've looked through the wheel thread already but I'm really just doubling checking I'm ordering everything correctly. I could just put 19" peelers straight on with my S Line springs but i want it that fractional bit lowered further to get rid of the gap.
    With this setup would spacers say 10mm make a huge difference to the way it sits also?
    Many thanks!
    Established Member Two Rings PurdueB8A4's Avatar
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Also interested in seeing this...
    2009 Quartz Gray Metallic Audi A4 Prestige
    aFe | Akebono | APR
    Mar 01 2015
    Salt Lake City, UT USA
    I installed H&R's OE Sport Springs and Rear Sway Bar last fall on my S4. Could not be happier with the look and handling.
    http://www.audizine.com/gallery/show...hp?photo=83650
    2015 Audi S4 | Florett Silver | 6MT | Sports Differential | Black / Magma Red | Carbon Atlas | Rear Side Airbags | Technology Package | B&O System
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Check out my build thread. Basically what you are looking for, just have the rotor wheels instead of peelers.
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Mar 26 2016
    Yeah thats exactly the look I'm going for, thanks for the help guys much appreciated!
    Mar 26 2016
    Have you used any spacers on that setup?
    Dec 19 2006
    996TT
    San Antonio, TX
    Yes, I have 10mm front and back
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Depending on what offset of peelers you get, you may not need spacers. Replicas exist in a 19x8.5 ET35 fitment, which sits essentially flush without resorting to spacers. OE (for the A4, at least) is 19x8.5 ET47. S5 peelers are ET33 and I think they're wider, as well; @goreckless has a set on his car and they sit perfectly.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Mar 26 2016
    Yeah the replicas that are available here in the UK are 19x8.5 ET35, I'm not 100% sure if the quality are any good though
    Mar 26 2016
    Quote Originally Posted by geokend View Post
    What drop in the springs did you have for that? 35mm or 40mm? Theres a few different size of the sport springs over here in the uk and not too sure which will be best?
    Mar 01 2015
    Quote Originally Posted by MagpieMatt View Post
    Part numbers might help you. I installed the "OE Sport Springs" part number 50361-55 giving a 1.2" drop. The "Sport Springs" part number 50361 gives a 1.5" drop.
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Did you upgrade anything else on the suspension or keep stock, i.e. shocks?
    aFe | Akebono | APR
    Mar 01 2015
    Just the springs and rear sway bar. Everything else stock.
    Mar 24 2014
    You should have no problem getting 19s under that setup. Watch out for your shocks, though, if you haven't matched them to the springs. They likely won't last too long. This has nothing to do with what wheels you're running, though.
    Mar 26 2016
    Quick update! Picked up some used replica 19" peelers up today, a women listed them on eBay late last night and i went to collect them early this morning with practically new tires on for £300 absolute steal! Soon as i got them i gave them a clean, now I'm just trying to decide on what spacers and springs to get :/
    They are 19 x 8.5 ET45 with 255,35,19 tires on. I understand the more flush fit tends to be ET35 so if i put a 10mm spacer back and front would this work out pretty much flush?
    Also here in the uk theres no h&r oem springs, there's only 30mm all round drop or 40mm all round drop I'm not too sure which would be better, after searching the wheel thread once again i can't find anyone with the same wheel & tire setup as me.
    [IMG][/IMG]
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    [IMG][/IMG]
    I run 19x9 et33 and am pretty flush. If you add a 10mm spacer to your 19x8.5 et45, you will still be 8mm away from being flush. To be perfectly flush, you may want to go 20mm spacers all the way around. That would put you at 2mm beyond my current set up.
    Check out this offset calculator and play around with the numbers to see what I'm talking about.
    https://www.1010tires.com/Tools/Whee...et-Calculator#
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Mar 26 2016
    Quote Originally Posted by doowopaudi View Post
    Thanks for the link! I sometimes use it for business and tend to have tools in the back so i don't really want rubbing issues at all and its a worry with my big tires, i want reliability and decent sporty look, i might just play it safe and aim for ET35
    Aug 10 2011
    North Whittier
    I once ran et35 peeler replicas and they looked pretty flush as well.
    Established Member Two Rings na_v's Avatar
    Jan 27 2015
    Also hopping on this thread haha
    So i have a 2014 Audi A4 Progressiv ( premium plus )
    Currently on 18 inch stock wheels
    i plan to lower it with H & R Sport Springs today 1.5" drop
    i want to order some spacers but not sure what mm to go with for a flush look.
    also my daily driver, would 20mm rear and 15mm front be a good setup?
    thanks
    Current : 2013 S5 Premium Plus | Glacier White | Magma Interior | DSG | ADS | Sport Diff | Carbon Atlas | B&O | Adaptive Lights
    AWE Track Exhaust | PUR 4OUR Forged Wheels | ECS Spacers | Carbon Imports Trunk Lip | Carbon Imports CF Mirrors | ECS Carbon Fiber Intake
    Past : 2014 Ibis White Audi A4 Progressiv | ECS Spacers | H&R Sport Springs | APR Stage 1 | RS Grille | US Millworks
    Dec 12 2014
    Bolingbrook/Illinois
    Quote Originally Posted by na_v View Post
    thanks
    I think you will find the answer you are looking for here.
    http://www.audizine.com/forum/showth...-Flush-Fit-Kit
    2012 A4 P+ quattro S-line appearance
    Mar 26 2016
    After finally learning that over here in the uk h&r don't supply oe sport springs their closest thing to it is just a sport spring with a 30mm drop, also managed to 2 sets of 10mm h&r spacers for the front and back. So with my ET45 alloys ill be ET35 so a bit more on a better with fitment.
    Would you guys go for slightly longer lug nuts to go with my spacers or will my standard ones be classed as "safe" ?
    When everything arrives in the post my next step is RS grill (with black sprayed slam panel as my a4's silver) I'm gathering everything together then putting it all on over next weekend when the weathers better here, ill upload pics soon!
    Also any tips or what to look out for?
