Results 1 to 6 of 6
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Question Bleeding the Clutch Slave Cylinder
    Halo,
    So I recently replaced my brake lines, drained all the fluid of course. Refilled. My Bentley Audi Manual says to bleed the clutch slave cylinder whenever bleeding the brakes. I've already bled the brakes, the problem is that the nipple on my slave cylinder is starting to get rounded, and I don't want to open it up, only to not be able to close it again.
    Is bleeding the slave cylinder necesary, or if I check my clutch and it seems fine, should I just roll with it?
    ~ ea
    Apr 22 2014
    Aptos, CA
    *bump*
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    you bumped it nowhere lol
    but for what its worth, I never blead the slave when I replaced a bad caliper, just the brake lines. never had an issue
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    The slave cylinder hydraulics don't have any significant complications that would trap air. Pretty much vertical in comparison to brakes and thus you almost never have to bleed it unless you open up the clutch hydraulics.
    Only reason to bleed it is during a brake fluid flush (every two years) to keep the fluid fresh.
    Senior Member Two Rings Germanguy's Avatar
    May 10 2005
    Manchester, NH
    Harold M
    2018 VW Golf R, '96 993
    Sold: 2004 VW Passat 4Motion,
    96 Audi S6, sold, F.U. NH emissions
    '87 VW QSW, '85 GTI
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I didn't bleed my clutch when I put my braided SS lines in. Your good.
