    Established Member Two Rings verstappen's Avatar
    May 05 2014
    B5 S4, B6 S4, B8.5 A4, 11 Audi Q5
    Phoenix
    OPEN DOOR message, where is the switch?
    Morning all, a couple days ago my dome lights and the open door message in the cluster came up, door was closed. Now it happens all the time, I am driving, go over a bump and the open door shows up on my cluster. It is also giving me trouble locking the car so I want to fix it this weekend. Is the switch located in the actual latching mechanism? Thank you for any info.
    With your mind power, your determination, your instinct, and the experience as well, you can fly very high.
    -Ayrton Senna
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Quote Originally Posted by verstappen View Post
    Yes.
    May 05 2014
    Phoenix
    Good stuff, thanks man. This shit is annoying....
    -Ayrton Senna
    Feb 18 2014
    Arizona
    I'm gonna guess that your problem is probably in the wiring. Check the loom that goes into the drivers door
    May 05 2014
    Phoenix
    Quote Originally Posted by 2004B6S4 View Post
    will pull the rubber cover later and check the wires, if nothing is evident then I guess I will pull the door card.
    -Ayrton Senna
