https://goo.gl/photos/PMkgs7ZgjcCtvAXUA
Truly a one of a kind ride. Few (if any) exist like this one. 32 valve ABZ V8 engine, mated to a 5 Spd manual. Runs stock Motronic ecu(OBD functionality retained).
I built this in Feb 2014 and it's been my daily driver ever since.
99 A8 engine new timing components when built in 2013
034 aluminum flywheel insert
Southbend clutch
custom 2.5" dual exhaust with 2.5" downpipes and X-pipe
custom aluminum radiator and A/C setup(still need A/C lines made) Silicone hoses
dual 10" fans controlled by a 185 degree fan switch
external oil cooler and filter w/ 034 block plate, all AN fittings(no leaks)
A8 BBK w/ slotted rotors and braided lines
Ceramic pads
Suspension Techniques Coil Overs
Lots of new parts, all front control arms, driveshaft CV joints, tie rods.
Black interior.
This car is not perfect but it's been reliable enough to use as my daily driver for almost two years most of which was my only car. Also included is the wiring diagram(although the wiring is simple).
This has been my daily driver since 02/14. I drive it everywhere. Runs on a bone stock ECU with zero modifications to it so the engine runs just like it would in the A8. Overall it is a fun and reliable car but it does need some interior attention. Seats have tears in the normal place, bolsters look good. It is considered a project car so please don't expect a flawless car, especially for $4500! If you are not mechanically inclined or willing to do proper maintenance, this car is not for you(buy a Honda). The engine is all stock. I am looking for a quick sale, as hard as it may be to believe, I no longer need this car so it must go to make way for another even more outrageous build.
260-442-4028
Please be patient if I don't respond right away, I have a life and selling this car isn't enough of a priority to immediately respond to everyone.
Car is in NE Indiana, I will not travel. Cash only
