Results 1 to 25 of 25
    Jun 12 2015
    CA
    Lightweight 21x10 wheels
    Hi guys,
    I'm visiting from the Q5 forum. I'm looking for lightweight 21x10 wheels I can pair with some 285/35 Michelin PSS tires. There aren't a lot of Q5/SQ5 guys who care about wheel weight. I'm looking for 21x10s under 23 lbs, if possible.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by colby7 View Post
    Hi guys,
    I doubt that kind of weight is achievable in that size even with a fully forged design. You may be able to do this with a carbon fiber wheel, but you are looking at like serious money for this. My guess is that a custom forged design like from HRE in this size will be like 28 lbs +/-.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    I believe my 21" HRE P104s weigh in right at 22lbs.
    Edit - I guess a little bigger if the 10" are exactly 22lbs
    Found this from an HRE rep:
    Would love to get the weights if possible.
    21"x10.0" P101 22.4lbs.
    21"x10.0" P104 22.0lbs.
    21"x10.0" P107 22.8lbs.
    HRE Performance Wheels. For those who don't need to compromise.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Quote Originally Posted by tonymission View Post
    That would be nuts if they are that light!
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Jun 30 2012
    Woodstock GA
    Quote Originally Posted by madyspop View Post
    I can definitely tell a difference with unsprung weight. Even with the car lowered, it's a much smoother ride than before.
    Jan 18 2010
    Los Angeles, CA
    Quote Originally Posted by Vol 4.0T View Post
    In my opinion, spending 8-10K on a set of wheels is just so ridiculous that I don't even know where to begin. I realize some people try so hard to be "ballers" by having what they think is the absolute best of the best but I remember HRE wheels bending like pretzels from the B5 S4 days. I see not much has changed...
    https://www.google.com/search?q=hre+bent+wheels
    For the record, I got my wheels for under $100 a piece and they weigh 21.X pounds. They're nowhere near as big as 21's, but for the price it's hard to beat that. I realize their quality is likely shit compared to OEM but then again so are the HREs. At least mine can be scrapped to recoup a decent chunk of what I paid.
    To the OP, there's not going to be an economical way to accomplish what you want. Can you give us a bit of color on what exactly you're trying to achieve? Is this primary for drag racing? Are you going to be reducing the weight of your SUV in other ways too?
    HRE doesn't manufacture the inners/outers used. HRE uses inners/outers made by triangle alloys. all/most the higher end 3 piece wheel companies use triangle or ars. then theres the cheaper Chinese or Korean alternatives such as rimtec. the old school triangle hoops were single walled/rolled, were weaker and did bend easier. the newer and current stuff is double rolled now and really thick. im running 255/30/21 and 295/25/21 HRE wheels with the newer triangle hoops, my wife also drives the car in LA and im sure shes not anywhere as careful as me, hitting potholes, etc. and I haven't had a wheel bend on me yet. she did bubble one of the rear tires by hitting something and the rim was not bent or out of round.
    Jun 30 2012
    Woodstock GA
    Has it ever occurred to you that some people are not TRYING to be anything? When we're essentially discussing the top of the Audi product line, the incomes in here could range from probably $80-90k a year to multiple-millions per year. That's a huge discrepancy and a major difference in how people can spend. You have no idea where any of us fall on that spectrum. Your argument is essentially that you're much better with your money and would never not get maximum value on your dollar, but you're the one pulling the trigger on $100 wheels. Probably should have just stuck with the OEM wheels instead of wiping your ass with $400, right? What a waste.
    I know you refuse to reply to me because I keep calling you back out and you can't handle an argument without using an overwhelming amount of tech talk... so I'll expect the same here.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    He's a fucking clown. He embarrassed himself with the ridiculous matrix headlights crap and decided to lay low for a while, probably in hopes that people would forget. Now he's back in full force. Seemingly no thread goes by where he isn't offering multiple posts explaining why he knows all and the rest of us are idiots. I maintain he doesn't even fucking own a S6. Ass. Clown.
    Jun 30 2012
    Woodstock GA
    From what I've seen, it appears that people think because something is the most expensive it must be the best. Examples would be the HRE P101 wheels and Akrapovic exhaust. I can only speak for myself which is I why I prefaced the statement by saying "in my opinion." To me, it doesn't matter if I'm a peon, a millionaire, or a billionaire, I'm not flushing my hard earned money down the toilet by spending 8-10K on rims or 8K on a catback exhaust system. I'd rather improve my car by doing so on a budget where I get a much better return on the money I've spent. Which is why I bought the wheels that I did. They will mostly be used for the strip, they let me fit the drag radials that I wanted to run (won't fit on my stock wheels), and at the same time they reduce the weight by around 8-9lbs per corner (although that is negated by the much heavier than stock drag radials).
    Then just talk about what you're doing and I'll be interested to read. Your posts are informative, but why all the "wannabee baller" and sheep jabs? It's silly and I'm assuming you do it because it's the Internet and trolling is fun.
    I don't know enough about cars or have the time to learn/then do it on a true budget. I appreciate guys who do, but I just love driving and the finished result. In my months long search for wheels I considered many options... eyes just kept taking me back to the HREs, ears kept saying "yep I like that akra sound clip the most". So that's what I bought, just decided to buy on 100% personal preference only and not consider cost for this particular car build. That was a conscious decision.
    I don't see what's wrong with either approach to "building a car", but it seems you resent any way that's not your way.
    Mar 14 2008
    MA
    Some might think owning a twin turbo V8 is also ridiculous. Why do you need a car like this to begin with? Just get a Hyundai Elantra and it will get you from point A to point B just the same.
    Enjoy this....
    Ballers......most people here don't have to "try". They actually are.
    Veteran Member Four Rings zee007's Avatar
    Jan 12 2010
    2012 C63; 2017 X5M
    RVA
    Quote Originally Posted by VVG View Post
    Enjoy this....
    Best thing I've read on the internet today!! And that's saying a LOT - considering England beat Germany from 2 goals down!
    - Zee
    Current: MY22 RS6 | MY19 Q8 | MY74 50
    Past: MY09 TT | MY10 S5 | MY13 AllRoad | MY15 S6 | MY16 RS7 | MY17 911TT | MY17 X5M | MY17 Q7
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    Nice wheels man!
    at last a wheel thread that has the weight as a primary factor! lightweight wheels CAN improve overall performance.
    21s are too big for me and the freaking NYC roads. I went down a size for a taller tire that forgives more...
    2015 Porsche 911 Turbo S
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    I'm a simple man so I don't like to think so much about how others spend their money. If someone can spend money on something just to be a baller, good for them and I don't see anything wrong with that. We wouldn't buy these cars to begin with if we really want to spend money wisely so we are all in the same crazy boat anyway. I'm sure that the majority of camry or accord drivers would think that we are a bunch of idiots who spend ridiculous amount of money on something that its main purpose is to get you from point A to point B.
    No one here is really better than others.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Nov 19 2005
    Central IL
    Please share pics of these $100 a piece wheels, I can't think of a single wheel that would work on our cars that are anywhere near $100. Also you bought your S6 fro $36K, that has to be the lowest purchase price ever on a C7 S6. I'm assuming it's a pretty basic model at that price?
    Nov 19 2005
    Central IL
    Pretty basic model how? All 2013 S6s were Prestige package cars so they're already loaded from the start. Not everyone's a sucker and wants to get ripped off on a $6K B&O sound system when the standard Bose system is great.
    If you check online now, there are two 2013 S6s with asking prices of mid $30K's. With some haggling, you might even be able to get an S6 for $30K. But then again I did buy mine almost a year ago when prices were higher.
    If I posted a picture of the wheels, you and everyone else would surely laugh. They're pretty gross. But again, I picked function over form because I only plan to run these at the strip.
    I'm not going to laugh I just want to see what a $100 wheel looks like, what size are they?
    Senior Member Three Rings luv2sleep's Avatar
    Jun 12 2012
    Enjoy this....
    Niiiice! Would you mind posting a picture of your entire car so I can see how it looks? Thanks man!
    Jun 12 2012
    VVG, disregard! Duh.
    Jun 12 2015
    CA
    Perfect, this is just what I was looking for. The 104s and 107s are beautiful.
    Active Member Two Rings edwardg's Avatar
    Nov 02 2015
    spiders
    Bellevue WA
    I'm partial to the 107s myself... Here's mine in brushed dark clear. Getting them ready to go on the car pretty soon.
    Edit: these are 20" in case that wasn't clear. Just adding to the HRE p-series love. There's a series of pics of a Q/SQ5 (can't recall which) with P107s on the HRE website. Looks fantastic.
    2016 S6
    Mar 14 2008
    MA
    Quote Originally Posted by luv2sleep View Post
    Yeah....plenty of pics around, but here you go anyway. We all love to show our rides !!!
    HRE P43SC 20x9.5 ET39 in brushed dark clear with Michelin PSS 265/35/20
    Dec 05 2015
    Chicago, IL
    Quote Originally Posted by edwardg View Post
    Whoa, I like these!
    Established Member Two Rings martz's Avatar
    May 01 2014
    2014 Audi RS7, 2010 Audi Q7 4.2 TDI, 2014 Ducati SF848, 2003 Nissan 350Z Roadster
    Australia
    This Vol 4.0T guys is a baller at upsetting people.
    Apr 21 2014
    Hayden Lake, Idaho
    I'm going to exercise my "wanna-be Baller Status" VOL. Can you tell me VOL, what amount of money will make you leave these forums forever so as a collective group we no longer have to have your typed diarrhea polluting every single thread someone has on here? Please advise.
    2014 Audi RS7 - Daytona Gray Pearl / Carbon Optics / Carbon Mirror Housings / Carbon Inlays / B&O with 12" Digital Designs Custom Sub Enclosure and Digital Designs Amp / Full Xpel Wrap / APR Stage 2 Tune / Milltek Non-Res Exhaust / Milltek Catless Downpipes / H&R Module / Eurocode Sways & Endlinks / Gloss Bronze HRE P104 / Smoked Tail Lenses / Body Color Side Lenses / Empty Wallet
    Veteran Member Four Rings Not A Good Idea's Avatar
    Apr 26 2012
    Hmmmm...
    Li. Ny
    Quote Originally Posted by DrBeerMD View Post
    shit, i may have to start spewing nonsense if it involves a check :)
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Vol won't post a picture of his wheels...has he ever posted a picture of his car?
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
