Results 1 to 9 of 9
    Mar 02 2016
    Phoenix, AZ
    Best first step in better handling around corners-sways or coilers?
    I have done sways but never coilovers, but looking to improve the cornering as the car seems to want to roll more than I would think for such a small car. There are vendors on this site selling both reasonable but I would prefer to start with one at a time for now.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    If you're looking for better handling skip the foreplay and go with sways. If the wheel gap is killing you then coils first.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    If you're looking for responsiveness, choose the sway bars and a set of good tires before the coilovers.
    You'll be amazed on what can be done to improve steering 'snap' on a two-ton car with those parts.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Senior Member Three Rings Slim0531's Avatar
    Aug 05 2014
    2010 Santorini Black Land Rover LR4
    Installed 034 RSB over few days ago on my 2014 A4 and all I can say is that why I did not do this before? I feel confident driving on corners without slowing down like before.
    Sep 17 2006
    ^^^add in a beefy front sway and you'll feel like you're driving a go kart.
    past: B6 S4, B5 A4
    Established Member Two Rings hanif87's Avatar
    Feb 11 2015
    United States
    Quote Originally Posted by earhythmic View Post
    While at the same time increasing understeer.
    Sent from my LG-D851 using Tapatalk
    Sep 17 2006
    From my experience, totally not. I think that's a carried over myth from the B5 days.
    past: B6 S4, B5 A4
    Nov 12 2015
    JaguarFPace
    Henderson, Nevada
    Hanif87 is very much correct. Increasing rear sway stiffness decreases understeer. Just a simple fact how weight transfer works.
    Mar 02 2016
    Phoenix, AZ
    I am leaning towards EruoCode adjustable sways. I had Hotchkis on my ex's Allroad years back but the EuroCode seem the same specs. Anyone actually buying new hardware with install? I don't recall doing that with the Allroad and with adjustable sways wouldn't it make no sense since if you "adjusted" the setting it would require new bolts each time?
