Results 1 to 2 of 2
    Senior Member Two Rings Krmass25's Avatar
    Aug 18 2013
    AMERICA
    Thumbs up A4 B7 AQUAMIST HFS-4 Water-Meth system -Like New - Includes Intake Manifold - $900
    The HFS-4 is suited for Direct Injection applications with its multiple inputs to properly map the engines load in Direct Injected cars. These inputs include the fuel injectors, the MAP sensor, and the high pressure fuel rail signal.
    The HFS-4 uses a constant pressure PWM valve injection for precise metering of the injected fluid into the intake track. This ensures precise injection in relation to load ensuring crisp response across partial and full throttle loads and no over run on throttle lifting.
    All necessary wires and fittings included.
    INCLUDES:
    AQUAMIST HFS 4 ADVANCED METHANOL INJECTION COMPUTER
    2 GOLLON TWIN TANK WITH FAN AND BLUE LED KIT
    1600cc/min FAV
    5 PORT DISTRIBUTION MANIFOLD
    5 JETS: 4 x .9mm / 1 x .5mm
    5 JET ADAPTERS
    HIGH PRESSURE FILTER
    CHECK VALVE 15 PSI
    AUDI A4 INTAKE MANIFOLD PRE DRILLED FOR METHANOL SYSTEM
    $900 + $30 S/H (Large Package)
    Aug 18 2013
    AMERICA
    TTT
