Results 1 to 10 of 10
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Instructions on how to adjust lowering links
    Hey guys. Had an air ride suspension error go off last week. It went off but stored a code about some air ride fault in the rear driver side. While the code went away it messed up the cars ability to lower itself. For some reason it stayed at a higher level even in dynamic mode. Car would still raise and lower, just not go as low as it normally does. Took it to my performance dealer as my car is tuned. I bought my vehicle used and it does have lowering links. Saw them while at the shop today. They recalibrated the suspension and initially I thought the car looked perfect but have now realized the front wheels are now slightly higher than the back wheels. I'm not sure if they changed any of the lowering link adjustments. They did mention to me that my car was lowered too much and that might have been the reason for the air bag error. I would like to adjust the front wheels down lower to be even height with the rears. Does anyone have instructions on how to lower the links in the front? Do I shorten or lengthen the links?
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Dec 14 2011
    Dublin, OH
    Anybody help?
    Dec 14 2011
    Dublin, OH
    Bumping question back to the top. Trying to tackle this today. Short question on the front wheels do I tighten or loosen lowering links to lower the car.
    Senior Member Two Rings mwmaroney1's Avatar
    May 08 2012
    2014 S6
    You didn't say what brand they are but I'm assuming it doesn't matter. My links require you to shorten them to lower the car. How much it will lower it will vary brand to brand.
    Sent from my HTC6525LVW using Audizine mobile app
    Dec 14 2011
    Dublin, OH
    Okay. Thanks. The front end is about half inch higher than rears. I'm going to to tighten them one revolution and see what happens.
    Veteran Member Three Rings Demandred's Avatar
    Jul 25 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    Hope this helps you and others that need it - hope it can be read when zoomed :)
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Dec 14 2011
    Dublin, OH
    Awesome. Thank you!
    Dec 20 2006
    CAN
    Yes, shorter will lower it.
    Senior Member Two Rings IceyTys's Avatar
    Jul 12 2012
    2020 RAM 1500 Limited
    Dallas, TX
    According to the manufacturer every 1mm of length shortening, you achieve 5mm of drop. However there is a recommended max drop on the links
    My Audi life:
    Current
    2013 - S6 - Brilliant Black
    Gone but not forgotten:
    2003 - TT 1.8T 6MT - Quattro Roadster - Silver
    2010 - S5 6MT - Prestige - Phantom Black
    2004 - A4 1.8T 6MT - Ultra-Sport - Brilliant Black
    2003 - A4 1.8T - Ultra-Sport - Dolphin Grey
    Jul 25 2011
    Correct - as per pics.... Suggests no more than 8mm total
