Results 1 to 6 of 6
    Mar 24 2016
    Massachusetts
    19x9.5 Rubbing Issue Question
    Quick question, I'm trying to decide between the Avant Garage m510's in 9.5 or 8.5, and was wondering with a 245 or 255/35/19 tire, will I get any rubbing on stock ride or lowered on coils? I want to avoid going to low or introducing any negative camber, so would just like to have a little flexibility in the future even if I am keeping it stock height for now at least. Just wanted to double check real quick before I hit checkout, thanks in advance for the help
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    19 x 9.5 et40 - you can run up to a 255/35 and be perfectly fine at both stock ride height and a decent drop.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    I run 19x10 with a 40 offset and 275 30 in the rear, and up front I run 35 offset with a 5mm spacer on 19x8.5 245 35 tires and I am lowered with STASIS springs. No rub with 4 people in the car.
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    19x9.5 is a very common wheel size for the b8 a4. Its all about the offset though. ET 35-40 will be in the right range depending on the tire (245-255) is the best options
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    I'm running 19x9 ET 40 with 265/35/19. Very very minimal rubbing in the rear on dips, 255 should be a safe size.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Established Member Two Rings zxg01's Avatar
    Sep 23 2010
    1993 RX7 (1JZ swap in work)
    Quote Originally Posted by adamazing View Post
    That's the 510s I'm running with no issues
    Sent from my stang5litre Edition 5.0 using Tapatalk
