Results 1 to 3 of 3
    Nov 07 2014
    Nj
    2.0t front driver side axle for manual
    As title states need a cheap oem good condition axle for a manual Quattro 2.0t. Easiest way to reach me is text me 732 552 1437
    Nov 07 2014
    Nj
    Up
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    I know it's not what you're looking for, but i have a used reman axle (driver side, manual quattro). Not sure if that helps with a core return. The boots are going so it's probably only good for a core exchange.
    Also, I got an OEM used one from AutoHaas Parts in Patterson. http://www.autohaasparts.com/wordpress/
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
