Results 1 to 12 of 12
    Sep 08 2015
    Nashville TN
    Unhappy ?Enkei NT03 et35 B7 S4 fit?
    Will 18x8 et35 fit?
    I read on a few different forums that they didn't even make our 5x112, but a quick search on their site said otherwise.. Im just confused, someone help me out?
    I found pics and a post on them on a rs4, but no b7 s4 anywhere.
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    It depends on the width of the wheel. But et35 is usually a safe offset.
    "Brake last, finish first."
    Sep 08 2015
    Nashville TN
    I wish I could borrow someones set and see for myself lol
    I will be lowering the car too about 2 inches all around and I know that will play a big part..
    Oct 14 2009
    AZ/NY
    They will fit 100% the stock wheels are 18x8.5 et35. You are running essentially the same thing but a half inch more narrow on the wheel size. If anything I would run a wheel the same width or wider than stock but thats just my 2 cents.
    Sep 08 2015
    Nashville TN
    I really appreciate the feedback! I might go with a 18x9
    I wasnt sure on the stock specs, I bought my s4 few months ago. I love it
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 11 2010
    STL, MO
    Yes, they will absolutely fit. I'm running 18x8 +35 RPF1s with big brakes just fine.
    Sep 08 2015
    Nashville TN
    What size tire are you running Fulham? Im thinking of going 255/30 or 40.. dont know which would work better. 40 might rub on the arm
    Jul 11 2010
    STL, MO
    235/40/18.....255 would be pushing it, especially if you're lowered. I had 255's on 19x8's and they were a little wide. They hung over the lip of the wheel and rubbed on bumps(i'm lowered about an inch or so).
    Sep 08 2015
    Nashville TN
    Quote Originally Posted by FulhamFTW View Post
    Im wanting the meaty tire look, going to lower about an inch and a half. You got some pics of those rpf1?!
    Jul 11 2010
    STL, MO
    Keep in mind, I could use some spacers in the rear, but I think if you went 245/40, you would get the look you want.
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    Im running NT03+M, 18x8 +35 235/40R18, it work great.
    B6 Noggy Avant, B8.5 Allroad
    Sep 08 2015
    Nashville TN
    Dude your ride looks awesome . Glad you mentioned the spacers because I was actually thinking about getting some for the rear. The front I think would be fine!
    Hk, I need some pics man! I need to see em!
