Results 1 to 21 of 21
    Mar 14 2016
    Atlanta Georgia
    Doors locks me in!!
    Just drove my audi for the first time today and while I was driving it the my door started locking and unlocking by itself. I'm not sure if there is a thread already on this but if there is someone please point me in that direction!!
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Lol thread title made me think of the family guy where Peter gets locked inside his cars
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    My doors lock when I turn the key and unlock when I take the key out. Is that what yours does or is it just random?
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Mar 14 2016
    Atlanta Georgia
    Quote Originally Posted by cclarkb5 View Post
    Completely random. As soon as I hook the battery up it will just lock and unlock over and over
    Sent from my LG-H901 using Audizine mobile app
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    And I thought my passenger door not always opening from the inside inless the whole car was unlocked was bad. I'd say it has something to do with a control module/computer freaking out. Or bad wiring somewhere.
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Feb 02 2015
    1991 Audi 90 20v
    My central lock pump in the trunk got water in it because the drain was clogged. It shorted out and unlocked and locked just like you're descrining. Check your lock module for water.
    Mar 14 2016
    Atlanta Georgia
    Where in the trunk is the pump and the drain located?
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    Quote Originally Posted by tar View Post
    Pulls out popcorn* I wanna see how this turns out
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Rear passenger side quarter panel behind the felt covered side panel. Be careful of the metal grommets. The plastic tends to break when you pull on the panel.
    Doug
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, Frankenturbo F4-H Kit, Bosch EV14 550cc injectors, APR R1 Diverter Valve, Snow Performance Stage 3 Water/Meth Injection Dual Nozzle Setup, Majesty FMIC kit, SSAC Cat Back Exhaust, Podi Boost Gauge in center vent pod, ATP Test Pipe, K&N air filter, HID fog upgrade, eBay short shifter, Center LCD retrofit, Aero wiper kit, Eibach Pro-Kit lowering springs, 18” B6 Ultrasport, Firestone Indy 500.
    Mar 14 2016
    Atlanta Georgia
    Is there a way to disable the lock module without unhooking the battery?
    Mar 14 2016
    Atlanta Georgia
    Quote Originally Posted by Cybersombosis View Post
    Doug
    Is there a way to disable the pump without un hooking the battery?
    Dec 10 2013
    Borden, Ontario, Canada
    Unplug it
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Mar 14 2016
    Atlanta Georgia
    Quote Originally Posted by Bordom View Post
    Unplug it
    Do you know which specific one to unplug because there are 3....I'm sure if I unplug all three the car won't start right?
    Dec 10 2013
    Quote Originally Posted by kaleil View Post
    I think it's the top one. Unplug stuff until the car doesn't start lol
    IG: 24_et
    Sold:
    RIP:
    Mar 14 2016
    Atlanta Georgia
    Wouldn't happen to know which one of those wires it is specifically because if I leave the top unplugged the car starts but the power windows don't work. So I wanna cut the wires dealing with the power locks
    Dec 10 2013
    You need the CLP (central locking pump) to operate the windows as all the locks/windows work off of an air system. If you unplug it, you have to live without windows
    IG: 24_et
    Sold:
    RIP:
    Mar 14 2016
    Atlanta Georgia
    Got ya. Is there a fuse or relay that is specific to the power locks? That way I could unplug the fuse and just plug the clp back in?
    Dec 10 2013
    You have to look under the fuse panel cover as I don't know what fuse it is.
    Even if you take the fuse out, your Windows still wouldn't work because there'd be no power going to the CLP
    IG: 24_et
    Sold:
    RIP:
    Mar 14 2016
    Atlanta Georgia
    So if I plug the pump back in and take out the fuse concerning the power locks I still get now power?
    Dec 10 2013
    Yes because they're not electric locks. Everything works off air which the CLP provides to the entire system. If the CLP is not working, you can't use locks or windows
    IG: 24_et
    Sold:
    RIP:
    Mar 14 2016
    Atlanta Georgia
    Understood okay I learned something new. So the clp was wet due to the trunk leaking if it dries up will it be okay or does it need to be replaced now?
