Results 1 to 7 of 7
    Jul 01 2011
    Miami/Florida
    Need to find DIY to change AC compressor on a 2009 V8 S5. Dealer quote me $4100.00
    Please help, need to find a DIY or instructions on how to replace the AC compressor on my V8 S5. Dealer quote me $4100.00. AC compressor is $875.00 plus dryer, the rest is labor. They told me the engine needs to come out to replace it.
    Thanks in advance. I already searched but did not find anything.
    Veteran Member Three Rings rooneyy's Avatar
    Jan 08 2016
    Toyota 4Runner
    Sorry if this isn't the info you're looking for by I wonder if this would be worth it to consider?
    https://www.yourmechanic.com/service...or-replacement
    I've seen this service but not sure how well it works exactly. Worth a shot?
    Jul 15 2014
    Carlsbad, CA
    The replacement of the compressor may not be a difficult job, but the refrigerant that is inside cant just be released to the atmosphere. The modern ones are not as horrible as the old CFCs like R12 etc, but still not something that you want out there. That being said, you would need at minimum a recovery machine and bottle to capture whatever gas is still in the system. Then, once the new components are in, draw a vacuum to make sure no air is in there. You may not want to go to the dealer for the job as a good shop should be able to do it for cheaper, but I wouldn't think that it is something that you could do on your own in the driveway.
    AG M590 - AWE S-Flo intake - AWE Touring Exhaust w/res down pipes - KW HAS - E Codes - HiD Fogs
    Jul 01 2011
    Miami/Florida
    Thanks for the info. The dealer evacuated the system. So right now there is no R134 in it.
    Veteran Member Four Rings Hippiekiller's Avatar
    Nov 15 2014
    Las Vegas, NV
    Take it to a different dealer or find a reputable independent shop. I had mine done last year and while it was under warranty, was about 1/4 of that price.
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    3000 for labor?!?! 20+hrs to replace your compressor? Thats perhaps the most ridiculous stealership story Ive heard yet. I don't have a link to the DIY, but the job is certainly not complicated. Assuming you have an average capacity for the wrench, the right tools, and some patience. There is zero reason I can think of to pull the motor, except to increase your bill and maybe provide more room. I have no idea where the compressor is on the V8, but Id imagine putting the front end in service mode would give all the room needed and that takes 20 mins tops.
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    If I recall correctly the AC compressor is sandwiched between the motor and the subframe. It also faces backward and is actually chain driven.
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
