Results 1 to 12 of 12
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Bought ECU from an AZer, but cant reflash.
    I picked up an M-box not long ago from a member and for whatever reason, I cant reflash it using the EPL software. Says something about a communications error, but when I go to ID the ECU in the flash loader, it just says, "THIS IS THE RAM PROGRAM".
    Any thoughts as to why a [supposed to be] stock ECU would give issue?
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    Could it be chipped? Rather then flashed
    May 16 2008
    Guess I'll have to open it up and see, but seller assured me it came from a stock car, no modifications done to ECU. Weird.
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    May be bricked, that ID means that it's in programming mode.
    Might need to be booted.
    WTB (1) OEM A8 Flat Five 18x8.5 et45
    WTB Black 6spd Shift Surround
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I don't know why it's doing what it is, but if it were my ecu I would try reading it with the Nef software. If that was successful I'd then try writing a stock bin to it. Finally I'd try the Epl flasher if things worked with the Nef program. It almost sounds as though it was unsuccessfully flashed and the flashing application did not close out properly.
    May 16 2008
    Quote Originally Posted by FlyboyS4 View Post
    I'm probably one of the few people who doesnt know how to use the Nefmoto software. I'll have to check into that, but at least that's a place to start.
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    you could jump on nefmoto and cruise the forums, im sure there are posts on similar situations, it does sound like its in boot loader mode or bricked or in programming mode, whatever anyone wants to call it. Probably needs some form of a reboot
    2008 Ibis RS4....GETing tuned
    Established Member Two Rings Gotwake424's Avatar
    Dec 14 2014
    DavidhogAJ
    Philippines
    I'd open it, make sure it isn't chipped.
    If it isnt't i'd would load up nefmoto and see if you can do a full read of the ram.
    If that doesn't work do what others have said and read nefmoto forums and get it into bootmode so you can reflash it
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Does the check engine light and epc light come on when you turn the key to the on position? If not its bricked and has to be bootflashed like phia_dot said.
    Sep 11 2009
    NE
    It is locked in unfinished programming mode, e.g. soft bricked. You might have to get a galletto and require bench flashing. Some Nefmoto'ers can do it for a small fee, it is not an easy thing to do if you're not used to play with electronics as it requires opening it up and putting into programming mode and using bench harness which only dedicated people have...
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Quote Originally Posted by julex View Post
    this is true ive always wanted to make a bench flashing area but have never needed one bad enough to make space for one
    also that sucks to have possiably bought a bricked ecu
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Sep 11 2009
    NE
    Quote Originally Posted by hibiscusS4 View Post
    Hey, how you've been?
