Results 1 to 10 of 10
Thread: Wheel Rotation
    Account Terminated Two Rings
    Dec 29 2014
    mgimmeMGD
    Usa
    Wheel Rotation
    Took my car in for 15K service and saw that my tires were between 3/32' to 5/32' tread depth remaining.
    My question is does anyone get their tires rotated and how often as the service did not rotate. I figure Quattro wears out more evenly and that nobody really does it?
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I don't get my car for another couple weeks. but unless the sizes are staggered, (wider in rear - I don't think they are, but not sure) I see no reason not to rotate. You still have front wheels that are turning the car in addition to rotating. Also, the bias for power to the ground, the front over the rear will wear the front and rear differently too. Just because it is an all-wheel drive does not mean all 4 wheels pull the load equally.
    Senior Member Three Rings DarkSideGTI's Avatar
    Feb 05 2008
    SL,UT
    I rotate every oil change.
    2017 Avalanche Raptor
    2015 Monsoon Grey S3
    Senior Member Three Rings miro01's Avatar
    Mar 26 2012
    '97 B5 A4, '15 8V A3
    OC
    Dealer didn't rotate my wheels either when I took it in for its 35k service. I did it myself at 30k though.
    Sent from my SM-G925T using Tapatalk
    Dec 29 2014
    mgimmeMGD
    Usa
    Talked with my service advisor about why they don't do rotation. He told me that its best to leave the better tires in the back because in an event of an accident, you can control the front wheels and need the tread for the rear traction on the vehicle.
    He also told me that the OEM summer performance tires last 20k~ miles or so which is common in all S cars. Guess i have another 5k~ to go and get some PSS.
    Feb 05 2008
    SL,UT
    that makes no sense to me. out cars are FWD biased and you would want the better tires up front.
    Apr 07 2012
    Oregon
    Wheel Rotation
    Quote Originally Posted by DarkSideGTI View Post
    You would think so. However, even the tire manufacturers say to keep them on the rear. I think the thought process is that most all drivers on the road can somewhat retain control if the front tires lose traction, to a good degree. However most people aren't able to control when the back end loses control.
    Oh, I don't have the S3 (just a Quattro A3) but I rotate my tires every 5,000 miles. I still have about 5/32" left on them at 32k miles. I change my oil every 5k also, so it's just easy to do it at the same time.
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    I'm with wildhareM5. Oil service and rotation every 5k. I also cross rotate the fronts to the rear to help keep wear more even.
    Dec 22 2015
    Well that is my plan. I will do oil/filter and rotation at the same time, either every 4 or 5K miles. Cheap insurance to keep the internals clean.
    Aug 13 2015
    Cali
    It makes sense because the motor is up front and subsequently more weight. There is naturally less weight in the back and those tires will loose traction in wet and snowy conditions first. You want to have the better tires out back because of that reason. It has nothing to do with an accident.
