    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Oil pressure datalog throughout a WOT pull.
    Hi guys,
    I am searching for an oil pressure datalog throughout a WOT pull
    on a 2.7T engine. Did anyone ever do this, I need to compare it
    to something.
    Oct 27 2011
    TOYS
    Philly Suburbs
    From my build thread:
    http://www.audizine.com/forum/showth...1#post11460348
    I have my oil pressure gauge in the oil feed line right before my turbo. Here's some oil pressure data. I'll get some logs to 8500 or so as well. Oil temp was at 225°F and the oil is Rotella T6 Full Synthetics 5w-40 with a Mann oil filter. This is my original 120,000 mile oil pump as well.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Do you have the actual data file that I could process? Thre are too many pulls in there :) Also some better resolution would be better. I know I ask for much :)
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Basically I am trying to diagnose a jumpy oil pressure (tested with 3 different sensors, all the same).
    My location is at the upper oil pan, where the OEM pressure sensor is.
    See how the black line jumps then smooths out?
    Oct 27 2011
    TOYS
    Philly Suburbs
    Yup send me your email
