Results 1 to 2 of 2
    Junior Member Two Rings
    Dec 09 2014
    Norwalk, CT
    Tip Transmission Leak Question
    '06 B7 S4, 105k, just had oil changed at dealership and they said I have a transmission fluid leak, but another visit required to pinpoint, clean things up, look, etc. I haven't crawled under car yet, but I think I can see the area that is oily around the back/bottom of the transmission pan.
    Any opinions on how likely this is pan gasket versus say a seal that requires pulling the transmission? Car is driving fine, but I have noticed the odd transmission slip getting off and back on the gas again quickly, perhaps. No fault codes being thrown, but not sure low fluid would generate fault codes? Not so easy to check the fluid level, I guess, and don't want to damage anything. Given age of car I am inclined to take it to an indy shop (anyone know a good one in Westchester/Fairfield?) and let them do a transmission fluid/filter change, and have them take a close look at things as they do that?
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    It might be leaking from the pan, get under the car clean it up with brake cleaner drive for few days and check again where its leaking. If its low on fluid it will act weird. It might be leaking from cooler hoses too.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
