Originally Posted by
van462
Look closely on top of your water pump. Look from the drivers side, below the intake manifold. The black plastic housing with the hoses going to it and look for a anything pink colored. It will usually weep out and evap off not leaving a puddle but just the pink crusty additives. This is the most common leak spot on the 2.0T.
Agreed, this has happened twice to me, my third OEM Audi water pump failed after less than 12K miles. I'm on my 4th now in 90K miles. I have pictures of how the gasket fails, if the leak is bad enough, you'll notice some coolant on the noise insulation/plastic cover underneath the car that you remove when you change the oil. The coolant can leak on sensors too and cause all sorts of error codes.
I remember the Audi dealership told me it was normal to burn some coolant and that they would top-off for free. Don't let them tell you that BS if you're under warranty, any coolant use is abnormal and signifies an external (most common) or head gasket leak.
