    Nov 30 2014
    Dallas, TX
    Strange problem with brake lights
    So this has happened twice in the last week or so. I have an 04 S4 Base (about 130k miles), I parked my car outside overnight and when I got back to it in the morning, my brake lights (as well as the third brake light) were on. At first I thought I'd left my lights on, so I looked inside and realized that no I had not left my headlights on. I turned the knob to switch on my headlights and then turned them off again, went around back and saw that my rear lights were still on. That's when I saw the third brake light was lit so I pumped the brake pedal and that's when the lights went out. On both occasions this has happened, it has been relatively cold outside (about 40-45 F which is cold for Texas) so I was wondering if anyone else has had this problem? I have never seen it before, and it hasn't happened (yet) when I've parked in an underground lot overnight. What could it be? Brake switch? I'm posting in the A4 forum as well.
    Established Member Two Rings RedS4avant's Avatar
    Jun 26 2015
    Way out in the sticks, BC
    Sounds like brake switch under pedal is on its way out and needs replacings
    Jan 14 2009
    Audi's
    Quote Originally Posted by RedS4avant View Post
    YUP! Be sure to use the search tool for other issues OP as they aren't new and have happened already.....
    Nov 30 2014
    Dallas, TX
    Feb 18 2014
    Arizona
    I suggest changing the switch asap. I procrastinated dealing with this issue for a long time, normally I'd notice the lights on at night so I'd tap the brake pedal and that would turn them off. eventually it killed my old battery, so I got a new battery but still didn't change the switch right away since I didn't have much time and that was less urgent, then one time I left the car parked without driving it for a few days and didn't notice that the brake lights were on, and with the healthy new battery those bulbs stayed on long enough to melt and distort the plastic housing around them. had to get new brake lights
