Results 1 to 6 of 6
Thread: PCV help
    Aug 01 2014
    Ohio
    PCV help
    Hey all,
    So I think my PCV may be causing a vacuum leak/rough idle. When in park, car goes "chug chug chug chug" (only way I can describe it haha). Also, when I shut my car off, the PCV continues to make a whirring/running noise for about 5-10 seconds before going quiet. Not sure if that's normal or not. I have also read the whole trouble shoot involving taking the oil cap off. Mine has suction on the cap. To that point, I read that either a) thats good, or b) thats bad.
    Something else I noticed is that the rearmost hose attached to the PCV seems to be whistling at the connection. Tried to use my finger to see if it was blowing air or sucking air, but I couldn't feel anything. Covering it though kind of muffled the sound.
    It's a 2005.5 B7 2.0t. I did replace it at 88k miles. Now at 104k. Wondering if I need to find the updated one. Or if recently putting in a new exhaust killed the one I had.
    Any ideas on what it could be? Failing PCV? Bad connection at the hose?
    Jun 26 2008
    Chicago, IL
    For the 10th million time replace your PCV or get a catch can setup. /end thread /eatfrostedflakes /grrrrrrrreat
    Aug 01 2014
    Ohio
    Thanks Tony
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by cg91 View Post
    Hey all,
    Replace the breather hose. It shouldn't fail in 20k miles
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Oct 24 2015
    Perth, WA
    Mine did in 5 mate, they're a bit hit and miss especially when tuned I think.
    My respray thread
    Aug 01 2014
    Ohio
    Haha well shit. I replaced the PCV yesterday. It was actually kinda gunked up. Seems to be working fine now but we'll see. Thanks guys
