Results 1 to 3 of 3
    Jan 26 2016
    london/ON/canada
    A4 2002 key fob issue
    Hey audi guys, id like to see some suggestions or ideas on what i can do to my problem. Thanks in advance. Recently my key fob went down, i changed the battery but still wont work (key fob). The key is perfectly fine which is good because it will let me start the car at least, but i cant lock the doors, open the car with the control or trunk. The problem is overnight i have to lock the car from the inside but only will lock 3 doors ( passenger, back ones). Driver side will remain open. Now lets say if i order one from ebay or get a key fob that matches my serial key fob number, could i just replace my key to the new key fob and just reprogram it? . Keep in mind it is only the half bottom piece from the key fob that is not working (buttons). And how do i know that this is just a problem with the key fob and not with the computer lock system? ....
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Have you tried the basic resync? Put the key in the ignition switch. Turn it to the on position (do not start the engine ). Wait 5 seconds. Turn the key to the off position. Press the lock button on the key. Done.
    Feb 12 2008
    Michigan
    The lock cylinder in your door does not work either? Cannot manually lock the car with key from drivers door?
