Results 1 to 4 of 4
    May 20 2015
    03' Mercedes-Benz C230 Kompressor
    New York
    B7 a4 motor help!
    Hello, my beloved b7 has a pretty much seized engine. I did the timing belt at 131k under my ownership I'm at 141k was getting ready to change the cam follower and my motor seized I started here if this ticking while driving it one day I started to slow done and y car started shaking violently and stalled in a matter of seconds and the oil pressure ligh flashed right before it turned itself off, I believe my oil pump went also my cam shaft snapped as well. I'm Trying to replace motor via eBay but not sure what motors are compatible. I have a 2006 Audiba4 2.0t Quattro and it has a bpg code motor. Need help asap !
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    There is a whole thread about it, manuals can use manual/cvt engines while the automatics can use them all. Look for that thread.
    What ever makes sense go with the opposite and you got it
    Mar 24 2013
    Oakdale, CT
    BPG or BWT from a manual or CVT car are direct swaps. A BPY from a transverse Audi or VW will also work if you swap the oil pickup, oil pan, turbo, and all exterior accesories.
    -Adam
    Jun 17 2013
    jersey city nj
    Tiptronic 2.0T engine are a dime a dozen. The manuals cost more do to . Check CL in your area luck
