Results 1 to 9 of 9
    Nov 28 2015
    Montreal, QC
    brembo front caliper ; same on 2.0 and 3.0 ?
    Hey guys, looking at the b8.5 Q5, is the front caliper the same brembo caliper despite the different size in rotor ?
    thanks !
    Senior Member Two Rings Lockon_B7's Avatar
    Oct 17 2014
    New Jersey
    They are both 4 piston front calipers that use the same brake pad. If that answers your question :D
    2016 A4 auto P+ Daily driver
    2016 S3 Sepang Blue Sold
    2009 A4 2.0T, 6MT, P+, Sport Package, Meteor Grey. Sold
    2008 A4 2.0T 6MT RIP
    Nov 28 2015
    Montreal, QC
    So I suppose then they are in fact the same, just 2 different size of rotor... Not sure why audi would do that, just cost more to produce 2 set of rotor than just one lol.
    Veteran Member Four Rings spijun's Avatar
    Oct 11 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by waxxonMTL View Post
    thanks !
    According to Audi catalog are not the same
    Front Brake Caliper Q5 - 320X30MM
    Left:8R0615107F - (old s/n 8R0615107D)
    Right:8R0615108F - (old s/n 8R0615108D)
    Front Brake Caliper Q5, A6, A7 - 345X30MM
    Left: 8R0615107G - (old s/n 8R0615107A)
    Right:8R0615108G - (old s/n 8R0615108A)
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    Yeah I'm with you - but they probably sell 90% + non 3.0 around the world and use those same rotors on other cars so it might actually make sense from a cost perspective. I've actually seen some 3.0s in the lower trim levels with the smaller calipers as well.
    Btw, the calipers have the 'carriers' built-in, so you can't just replace a carrier to run the larger rotors unfortunately.
    Nov 28 2015
    Montreal, QC
    thanks for the info ! i now have to be extra careful when buying used.. lol
    Jun 26 2014
    Brooklyn
    more competition!
    I'm hunting for a set myself. Already picked up the appropriate rears.
    Established Member Two Rings Yoshimura's Avatar
    Nov 25 2012
    Montreal
    Visual differences: http://www.audi-sport.net/xf/threads.../#post-2387478
    2018 S5 Sportback Technik - Sport Differential / Adaptative Suspension
    Nov 28 2015
    Montreal, QC
    thanks for the link !! it's now very easy to spot... if it has a hole its 345mm.. if it doesn't have a hole between the 2 mounting point, it's a 320mm ! :)
